1 members (dt235sd),
307
7
Mod | | | Forums66 Topics128,159 Posts1,057,039 Members48,460 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2009 Posts: 171 'Bolter | | 'Bolter Joined: Oct 2009 Posts: 171 | Hello, the end clearance at the intermediate bearing is at the crankshaft of my engine about .o16 inch. Is this too much to keep the engine working? Ask Wolfgang | | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | Do you mean the crank play fore and aft?
Ed
| | | | | Joined: Oct 2009 Posts: 171 'Bolter | | 'Bolter Joined: Oct 2009 Posts: 171 | | | | | | Joined: Feb 2004 Posts: 29,871 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,871 | Normal end play is .006" maximum. Are you working with new or used main bearings? A new bearing might get you closer to specification if the thrust face of the crankshaft isn't worn badly. Sometimes a wrong clutch adjustment will cause a constant pressure on the flywheel and crankshaft which wears out the thrust bearing and the crankshaft flange. Too much end play will sometimes cause an intermittent knock that's hard to find. Jerry
| | | | | Joined: Mar 2010 Posts: 10,305 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,305 | What is the procedure for measuring crankshaft end play on an installed 235?
| | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | Pull the pan, rock crank back and forth while measuring.
Ed
| | | | | Joined: Feb 2004 Posts: 29,871 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,871 | A pretty close estimate can be done without pulling the pan. Mount a dial indicator on the lower part of the bellhousing with the stem on the flywheel, and pry the harmonic balancer forward and the flywheel back. The movement of the dial needle will be the end play of the thrust faces. Jerry
| | | | | Joined: Mar 2010 Posts: 10,305 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,305 | Thanks Jerry. Thanks Ed, but what did I do to you lately for you to want to make me get all covered up with oil?  (Its a safe bet I do deserve it for something or another.) Carl
