1 members (1 invisible),
119
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,094 Posts1,056,059 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2012 Posts: 306 'Bolter | | 'Bolter Joined: Sep 2012 Posts: 306 | ** Would like to know if the 1953 Suburban drivers & passengers door and the lower clamshell use the same seal profile?? Thanks | | | | | Joined: Nov 2001 Posts: 1,517 'Bolter | | 'Bolter Joined: Nov 2001 Posts: 1,517 | Same rubber seal on all the doors, including panel and suburban. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | I hafta point out that Tims Steele links show a "2nd choice" cited as for doors needing a heavier seal [and is shown as working for the 53 panel/burb rear] - and Carter is totally wrong about that seal being for the 55-59 barn doors, Steele has the factory correct 55-59 seals - Carters would also be a "make do" for the 60-66 doors Bill | | | | | Joined: Oct 2005 Posts: 4,252 "Hey! I sound like Darth Vader!! | | "Hey! I sound like Darth Vader!! Joined: Oct 2005 Posts: 4,252 | Uh, oh. So are we looking at one type of seal for the '53 and earlier? Same as the side door seal. Or does the '53 and earlier take the '54 rear door style? | | | | | Joined: Sep 2012 Posts: 306 'Bolter | | 'Bolter Joined: Sep 2012 Posts: 306 | ** That is the 64,000 dollar question. ** My 53 Suburban was 99 percent orig. the only missing part was the l/h prop for the upper clamshell. When I removed the seal for the lower clamshell the seal kind of looked like the front door seals but after 64 years who knows? Am still trying to convince myself as to what seal to order.
Marzach,
This belongs in the Parts Wanted section. This is for the benefit of future readers of this out-dated post. And for your benefit: part sellers usually do not waste their time in other fora.
I will delete this post/thread tomorrow unless: Please edit post: delete "{Anyone Have Such A Critter}" and post this request in the Swap Meet ASAP.
Thanks, Tim
