2 members (Hotrod Lincoln, 1 invisible), 137 guests, and 2 robots.
Topics128,196
Posts1,057,385
Members48,471
2 Offline
I was thinking of replacing my 235 with a 454 my truck has the original frame and the engine would have to go where the six is not enough room to put it behind the cab do to the short wheel base. Has anyone done this if so what brackets did you use for alt and a/c
Crusing in the Passing Lane
Before going too far, what about your heat budget? Brackets will have to be made, shorter engine will give flatter floor, etc.
Ed
2 Offline
The truck has a/c and the floor and fire wall is insulated
I meant the heat capacity of the radiator-will it cool everything with existing or modern radiator with existing grille opening?
Ed
2 Offline
I know that at least on my coe the rad is 1 inch thicker than a pickup. The 235 does pretty well for what it is but some times I would like more power. with the air on and going up long hills the temp stays right around 180 which is what the thermostat is.
I was asked to put an LS1 (2014 corvette) into a 51 COE.
Didn't think it was possible so I mocked the whole thing up, Dummy engine block and transmission, Corvette manifolds (block hugging) and motor mounts.
Had the body off the frame exposing the additional cab support structure of a COE.
The taper in the frame rails and the support structure as well as the cross member made it out of the question for any one except a full custom shop that was equipped to do frame modifications and a lot more.
The only possible option would have been to move the engine rearward so far that half of the block would be sticking out behind the cab. Pretty dumb I think.
