2 members (baldeagle, Otto Skorzeny), 26 guests, and 5 robots.
Topics128,012
Posts1,055,318
Members48,419
#1236639 09/27/2017 4:08 PM
I have a 1956 235 that I just got. Did the hand turn of motor, started it up for a few seconds no problems,etc. Needed to drill the holes on the front mount so I put engine on a stand and removed oil pan and timing cover ; need to replace that timing cover seal as a little oil was present under it. Will also tap the bottom holes so I can keep the screws outside of the oil pan.The oil pan had no sludge at all in it very clean. so now I have the motor upside down so I could drill those mounting plate holes and thought it would be easier to work with the oil pan like that. my question is this....should I replace the rear main seal while it is opened up? I did not see any potential oil leakage in that area before I started. Can the seal be changed with the motor upside down? Never did any inside the engine work before so I'm kinda nervous about opening that darn can of worms. If I should change it would it be the rope or rubber seal? dont know what to do.
Ed
evac34 #1236643 09/27/2017 4:22 PM
"I did not see any potential oil leakage in that area before I started."
Was the engine recently running before you bought it?
If it was, and if it was/is not leaking, . . .
Nonetheless, Best Gasket sells good rear main seals (rope and rubber).
http://www.bestgasket.com/engine_catalog_years.asp?YearsCID=1953-62,%20235.......[543]
They say rubber seal for a 1956 235/261 - maybe others will post comments..
evac34 #1236798 09/28/2017 3:18 PM
no one has any thoughts????
evac34 #1236799 09/28/2017 3:27 PM
You will be happier if you do it once instead of twice. Replace what you can while it’s apart.🛠
