1 members (Gray_Ghost),
79
Mod | | | Forums66 Topics128,024 Posts1,055,395 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2005 Posts: 123 Shop Shark | | Shop Shark Joined: Nov 2005 Posts: 123 | I have a 1956 235 that I just got. Did the hand turn of motor, started it up for a few seconds no problems,etc. Needed to drill the holes on the front mount so I put engine on a stand and removed oil pan and timing cover ; need to replace that timing cover seal as a little oil was present under it. Will also tap the bottom holes so I can keep the screws outside of the oil pan.The oil pan had no sludge at all in it very clean. so now I have the motor upside down so I could drill those mounting plate holes and thought it would be easier to work with the oil pan like that. my question is this....should I replace the rear main seal while it is opened up? I did not see any potential oil leakage in that area before I started. Can the seal be changed with the motor upside down? Never did any inside the engine work before so I'm kinda nervous about opening that darn can of worms. If I should change it would it be the rope or rubber seal? dont know what to do. Ed | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | "I did not see any potential oil leakage in that area before I started."
Was the engine recently running before you bought it?
If it was, and if it was/is not leaking, . . .
Nonetheless, Best Gasket sells good rear main seals (rope and rubber).
http://www.bestgasket.com/engine_catalog_years.asp?YearsCID=1953-62,%20235.......[543]
They say rubber seal for a 1956 235/261 - maybe others will post comments..
| | | | | Joined: Nov 2005 Posts: 123 Shop Shark | | Shop Shark Joined: Nov 2005 Posts: 123 | no one has any thoughts???? | | | | | Joined: Apr 2005 Posts: 7,440 Bolter | | Bolter Joined: Apr 2005 Posts: 7,440 | You will be happier if you do it once instead of twice. Replace what you can while it’s apart.ðŸ›
