0 members (), 74 guests, and 0 robots.
Topics128,048
Posts1,055,540
Members48,425
#1236690 09/27/2017 11:16 PM
So, now I found a 1948 1/2 ton short wb frame. Will that fit a 1950 1/2 ton short wb cab and bed ? Thanks in advance
I just finished a 1946 chevy pickup street rod
now on a 1950 chevy 3100
also a GMC 220 with duals
and a 1948 chevy 2 ton
Wait to hear from others - I think "yes" as to working with a 1950 3104 cab and bed
By the way, there was no 1/2 ton Chevrolet long wheel base until the mid/late 1950s (Task Force trucks).
Yes. There may be a difference in mounting tabs on the cab but that is an easy fix.🛠
Should work just fine.
The 50 cab has mounts at the back on each side of the frame, you will need to drill holes in frame rails for them if not already available.
The 48 cab has a single center rear cab mount, can't use that mount in later cabs.
1952 Chevrolet 3800 pickup
---All pictures---
I did what you are trying to do. Find someone who has a 49 or later truck and see if he will let you take some precise measurements of where the holes need to go. The precise location of these holes his crucial for making cab alignment easy.
Carl
