| | | Forums66 Topics128,042 Posts1,055,518 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2016 Posts: 56 Wrench Fetcher | | Wrench Fetcher Joined: May 2016 Posts: 56 | So, now I found a 1948 1/2 ton short wb frame. Will that fit a 1950 1/2 ton short wb cab and bed ? Thanks in advance
I just finished a 1946 chevy pickup street rod now on a 1950 chevy 3100 . also a GMC 220 with duals and a 1948 chevy 2 ton | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Wait to hear from others - I think "yes" as to working with a 1950 3104 cab and bed
By the way, there was no 1/2 ton Chevrolet long wheel base until the mid/late 1950s (Task Force trucks). | | | | | Joined: Apr 2005 Posts: 7,440 Bolter | | Bolter Joined: Apr 2005 Posts: 7,440 | Yes. There may be a difference in mounting tabs on the cab but that is an easy fix.ðŸ›
| | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | Should work just fine. The 50 cab has mounts at the back on each side of the frame, you will need to drill holes in frame rails for them if not already available.
The 48 cab has a single center rear cab mount, can't use that mount in later cabs. | | | | | Joined: Mar 2010 Posts: 10,272 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,272 | I did what you are trying to do. Find someone who has a 49 or later truck and see if he will let you take some precise measurements of where the holes need to go. The precise location of these holes his crucial for making cab alignment easy. Carl
