3 members (PAUL Berardi, Jon G, JW51), 98 guests, and 1 robot.
Topics128,131
Posts1,056,373
Members48,441
#1230679 08/18/2017 8:24 AM
2 Offline
my 51 coe has the original wheels and rear but the truck was lowered. I want to haul 2 harleys on it. it rides fine with out motorcyles but with them on it needs to be raised up. has anyone used air shocks or bags with out alot of problems.any pictures would be helpful 2 harleys are about 2000 lbs
Crusing in the Passing Lane
Firestone makes some add-on air bags that might have that capacity.
Ed
To add to Ed Pruss' comment,Ridetech offer a simple bolt-on air bag assist springs which can be added to leaf spring set-ups,here's one rated @ 2000lbs,there are other options available too.
Air over leaf springs.
I think this is what you're looking for.
More pix on Flickr.
2 Offline
thanks for the info
I use Air Lift's version on my 2007 1500 Chevy. They required two 1/2" holes in the frame for upper bolts and bolted to axle on bottom. They work excellent they will level the truck out with my 1800lb+ truck box camper. Took about 1 hour to install. Ride is horrible without them, squatting and even braking feels better once levelled.
1952 Chevrolet 1700 Bickle Seagrave
"Old Smokey'"
Following the build in the DITY Gallery
Gabriel air shocks add carrying capacity but can be aired down. At flaps and Amazon.
Ron, The Computer Greek
I love therefore I am.
1954 3100 Chevy truck
2017 Buick Encore
See more pix
The Firestone/Ridetech air bags can be let down for light loads, pumped up again when heavy.
Ed
2 Offline
Thanks for the suggestions I installed the ride tech the truck seems to ride better also put 1 Harley on and added air till I got back to original ride hight it was pretty easy to install
