2 members (Wally / Montana, 3B),
138
Mod | | | Forums66 Topics128,080 Posts1,055,956 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2014 Posts: 357 'Bolter | | 'Bolter Joined: Dec 2014 Posts: 357 | So Y'all got ant tricks for installing this stuff. I can picture cutting the web every now and then. But is there any tricks I'm missing.
Julian Carter
1970 Triumph GT6 1967 Triumph TR4A 1952 Chevy 3600 1948 MG-TC
| | | | | Joined: Dec 2003 Posts: 2,953 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 2,953 | Just vee-notch the areas where the bolts will be in the way. I got mine from a VW supplier. Eight bucks for an awful lot. | | | | | Joined: Mar 2010 Posts: 10,275 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,275 | The only places you need to notch other than where the bolts are in the way is where there are sharp curves in the rear fender (if you are bothering to do the rear fenders).
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | "(if you are bothering to do the rear fenders)"
Carl is correct: if you are unnecessarily using fender welt in pickup bed fenders.
Pickups had no rear fender welt; however, panel-body trucks had rear fender welt. | | | | | Joined: Jan 2017 Posts: 308 'Bolter | | 'Bolter Joined: Jan 2017 Posts: 308 | Won't the fender welt dampen vibration. My 49-3100 had them front and rear only the rear has been painted so far. https://www.flickr.com/cameraroll/ | | | | | Joined: Dec 2014 Posts: 357 'Bolter | | 'Bolter Joined: Dec 2014 Posts: 357 |
Julian Carter
