1 members (UtahYork), 128 guests, and 4 robots.
Topics128,186
Posts1,057,318
Members48,469
Ok, most of my pieces (front fenders, doors, hood, etc) have epoxy primer on them and I have pretty much finished phase 1 of the body filler.. what's next? do I get a hose and spray off all of the dust and then spray my first coat of primer on them and then go back and do more body filler or what? What's the next couple of things that I need to do so I can keep the ball rolling? Thanks!
1952 Chevy 5 Window Restoration
Blake,
I think if you have covered all your clean, bright blasted metal with a 2K primer, then you are, as they say, golden!
You can Bondo and sand until the cows come home as long as you don't break through that primer coat to metal again. If you do, you will have to seal it.
When you are all done with your Bondo and other fillers, you will coat it all again with 2K again (I think). This will seal the porous body filler and allow all top coats to gloss and dry evenly.
All you care about is keeping any bare metal sealed from the atmosphere.
Stuart
your using ppg epoxy and i believe that on thier tech sheet for that epoxy there is a different mix to use it as a sealer. you need to use a sealer so that the topcoat doesnt soak into the sealer. im not sure if 2k primer can be used to seal but i know epoxy can. for any other ?'s you can ask the guys at
autobody101
it's not old it's "aged to perfection"
http://brent5631.myphotoalbum.com/
I went today to a auto paint store.. they priced me at $120 for 1 gallon of chassis paint, 1qt hardener, 1qt reducer.. I guess I'll buy that and go ahead and shoot my frame next week.. then the frame will be done!
i got realy good frame paint off ebay 160. per gal. got it fo 20. so i got 2 gallons
nice, what is recommended for frame paint? ebay may be the way to go!
I personally think that the black zero rust looks great on the frame!!!
Tim Sheridan
1947 First Series Chevy 1/2-Ton
"Liberty Series" - "Art Deco" - Whatever you'd like to call it.
Blake
I shot mine with epoxy from NAPA and them used TSC tractor paint. Tractor paint was 20 bucks a gallon,10 for hardener and picked up reducer at Home Depot. Pics below
Dan
http://rides.webshots.com/photo/2951450480071274430qeOjmO
Two engine stands make a rotisserie...
NICE TIP.
Thanks Dan.
mark.
'51 KY 3100
