1 members (delky), 65 guests, and 2 robots.
Topics128,049
Posts1,055,740
#1235765 09/21/2017 4:08 AM
Hi guys. I picked up a 1958 3800 1 ton recently. I started thinking about when the time comes that I'll need parts. Im referring to brake parts, drums , shoes, wheel bearings, etc. I better mention that it is a dualie. Im hoping parts for a 3600 3/4 ton are the same. I knew somebody out there would know. Thank You
1 Offline
I am not familiar with that new a truck but after 1951 the 3800's have Bendix brakes and I am sure parts are more available than the old Huck Systems . Persons in the know will be along shortly.
3B Offline
Hy Mike Cochran, welcome, as with many of the trucks some parts interchange some parts do not. Your truck probably has fourteen inch diameter rear brake drums, these drums have been extremely hard to find for quite a while. Many guys have chosen to replace the rear axle with a more modern one that has available brake parts, hope that helps.
Crusing in the Passing Lane
GM ff 14 bolt axles are cheap, plentiful, several modern ratios.
Ed
EdPruss #1236013 09/22/2017 11:05 PM
If possible, I'd want to change the 3rd member so I could do away with the dual wheels. Also, do something about the fronts. I dont want anything to do with wheels that have a lock ring. How about the running gear out from under a 3/4 ton? one piece rims of course. Any ideas of what trucks that have what I need are greatly appreciated. I might even build it as a 3 on the tree if I find the right 3rd member.
Moderated by  Dusty53
