| | | Forums66 Topics128,052 Posts1,055,728 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2012 Posts: 5 New Guy | | New Guy Joined: Dec 2012 Posts: 5 | Hi guys. I picked up a 1958 3800 1 ton recently. I started thinking about when the time comes that I'll need parts. Im referring to brake parts, drums , shoes, wheel bearings, etc. I better mention that it is a dualie. Im hoping parts for a 3600 3/4 ton are the same. I knew somebody out there would know. Thank You | | | | | Joined: Apr 2005 Posts: 396 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 396 | I am not familiar with that new a truck but after 1951 the 3800's have Bendix brakes and I am sure parts are more available than the old Huck Systems . Persons in the know will be along shortly.
| | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy Mike Cochran, welcome, as with many of the trucks some parts interchange some parts do not. Your truck probably has fourteen inch diameter rear brake drums, these drums have been extremely hard to find for quite a while. Many guys have chosen to replace the rear axle with a more modern one that has available brake parts, hope that helps. | | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | GM ff 14 bolt axles are cheap, plentiful, several modern ratios.
Ed
| | | | | Joined: Dec 2012 Posts: 5 New Guy | | New Guy Joined: Dec 2012 Posts: 5 | If possible, I'd want to change the 3rd member so I could do away with the dual wheels. Also, do something about the fronts. I dont want anything to do with wheels that have a lock ring. How about the running gear out from under a 3/4 ton? one piece rims of course. Any ideas of what trucks that have what I need are greatly appreciated. I might even build it as a 3 on the tree if I find the right 3rd member.
