5 members (Hotrod Lincoln, Otto Skorzeny, Jack Ryan, Slick Willy, 1 invisible), 123 guests, and 1 robot.
Topics128,162
Posts1,056,925
Members48,458
#1235189 09/18/2017 12:05 AM
Anyone know how hard it is to take out the entire dash of a 64-66 cab? considering the task and not sure it is feasible.
~ HB
1962 Chevrolet C10
1962 Suburban
Socket Breaker
Socket Breaker
There are a bunch of spot welds you have to remove if I recall correctly.
Also, I think the windshield and all the rubber has to come out to get to some screws or something.
I've never done it myself, but I saw a photo thread once where someone did it.
so, yes it is feasible, but it is a heck of a lot of work.
Then you have to remount it somehow.
What are you trying to accomplish?
Maybe someone on here knows another way to get it done. grin
-W
I will attach a picture when i get home that will describe the situation.
~ HB
1962 Chevrolet C10
1962 Suburban
Someone gashed the radio cut out. Need ideas to re-work. Donor dash is available but connected to cab.
~ HB
1962 Chevrolet C10
1962 Suburban
Classic Parts sells the center dash section if you want to cut it out and weld in a replacement panel.🛠
So does LMC Truck.
http://www.lmctruck.com/icatalog/cbe/full.aspx?Page=49
Item 20.
No need to remove the entire dash.
Ok. Thanks.
~ HB
1962 Chevrolet C10
1962 Suburban
Hambone,
I repaired my dash with a patch piece. Turned out good. Send me an email.
