7 members (TUTS 59, Otto Skorzeny, Gdads51, Gray_Ghost, Jon G, Rick Brown, Wally / Montana),
98
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,115 Posts1,056,594 Members48,448 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2009 Posts: 235 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 235 | I thought it would be really nice to put a brake booster on my '53 3600 as I saw them all the time when just browsing through catalogs. What I guess I didn't see, was that they were for the 3100 and only an automatic? I've got the 3/4 ton with a manual transmission. Of course, the transmission isn't in it yet, and the engine is a 235 out of a '55 car that had a hydro-glide - but all I have is the manual. Am I out of luck for a brake booster? I've looked at every site I can but I would love to be wrong if someone can point me in the right direction.
'53 Chevy 3604 Five Window Cab ('56 235)
| | | | | Joined: Jan 2016 Posts: 631 'Bolter | | 'Bolter Joined: Jan 2016 Posts: 631 | Depends ..........some of the reasons they says automatic only is because the three speed column shift linkage is the interference issue. If you have a 4 speed top shifter the linkage is not a issue.
Some instructions also mention the cross member must be modified with out says which cross member. Some are referring to a engine transmission conversion where the rear tail shaft cross member is added and causes an interference issue. | | | | | Joined: Jun 2009 Posts: 235 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 235 | Mines a 3600 with the shifter on the floor. I can modify frame if necessary but would rather not. Does that make a difference?
| | | | | Joined: Jun 2009 Posts: 235 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 235 | Please, anyone? I did find a booster kit for 3/4 ton (link below) but it's for their disc brake conversions. Could I use this with my master cylinder? Or is there a different booster someone knows about? Or could I use the 1/2 ton kits that are so abundant? Anyone? https://www.hollisterroad.com/proddetail.php?prod=4754BOOSTERKIT
