7 members (3B, Phak1, 1955 1 Series, Gib70, Joe H, KEVINSKI, 1 invisible),
133
Mod | | | Forums66 Topics128,092 Posts1,056,451 Members48,443 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2017 Posts: 8 New Guy | | New Guy Joined: Sep 2017 Posts: 8 | I have a dump bed on my 6400 that I don't need. Is it worth trying to remove it or shall I just weld it in place?
one of the rams has a leak and the hoses look sketchy.
I am converting the truck to carry a wood fired oven for catering.
'64 Ford F-100 '51 Chevy 6400
| | | | | Joined: Jan 2008 Posts: 4,962 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,962 | Almost every farm truck had a dump bed. I have about a half a dozen of them laying around and have no use for them. I would bolt it in place. Welds crack when they flex and the 6400 frame flexes a lot. | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | If you don't need the dump mechanism you'd save some weight to remove it. Then bolt on the remaining bed, or whatever you have to replace it. | | | | | Joined: Sep 2017 Posts: 8 New Guy | | New Guy Joined: Sep 2017 Posts: 8 |
