| | | Forums66 Topics128,005 Posts1,055,261 Members48,418 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2004 Posts: 313 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 313 | Guys,
I would like some opinions here please. I may possibly be looking at an engine overhaul on my 235 that is in my restored 54 Chevy truck. I am going to run a compression test and leak down test first to check the engine's health but if I have to end up pulling the engine, I don't want to damage paint, etc.
So, should I remove the front clip, or just the grille, radiator and core support and pull the engine out the front?
Thanks in advance!
1953 3100 with 1957 235, T5 and 12 bolt 373 rear
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | That is what we did with my Suburban - I think that we also removed the hood. | | | | | Joined: Mar 2004 Posts: 313 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 313 | Thanks Tim,
So you removed the front clip, or grill, radiator and core support ?
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | The radiator and radiator housing/support was removed as one piece. I think we removed this first, and I think it was tricky because I dimly recall the top-edges of the radiator support was "intertwined" with the inner/outer fender.
The fenders (inner&outer) and grill was removed as one piece (very slowly/carefully).
I think we removed them in that order.
It is a two person job; and, three people would make it safer. | | | | | Joined: Mar 2010 Posts: 10,270 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,270 | I would remove the entire front clip as a unit. You will have less chance of damaging paint. There are just too many fasteners which are difficult to get to in order to give you room to pull the engine. There is information that indicates that GM assembled the entire front clip as a unit off of the truck, then installed this unit on the truck.
| | | | | Joined: Jun 2006 Posts: 693 'Bolter | | 'Bolter Joined: Jun 2006 Posts: 693 | i'm going to go the opposite way. i'd leave the clip on. i think there is more of a chance to damage the paint trying to remove the entire clip and then there is the whole panel gap/alignment problem when its time to go back together. I've removed a half dozen engines in my life and never took off a front clip to do it. Seems like way more work than necessary.
you have to take off the hood, go slow, have helpers, and put towels/fender protectors on anything you think you might hit or scratch. did I mention GO SLOW?
Clearly both ways have been done by many so you'll have to choose the method you are most comfortable with. | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | When I do something like this, as I did with my 38 Master, I put green painter's tape along all the edges that are going to move, relative to their surroundings. Painter's tape is easier to remove after. | | | | | Joined: Mar 2004 Posts: 313 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 313 | Thanks everyone for your replies!
Truckernix, I definitely concur on using lots of green painters tape!
tomctomc, roger that on covering everything possible! The last thing I want to do, is damage the paint on my truck.
| | | | | Joined: Apr 2005 Posts: 2,832 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,832 | If your 54 was at our shop we'd guarantee no paint damage if the front clip was pulled but absolutely no guarantee if left in place. It is silly NOT to pull it to where it is completely away from any dropped tools, belt buckles, 600# engine swinging around, dangling chains, etc. I've seen dozens of trucks with the core support top cut out to clear a pulled engine. To pull with everything in place you first must have lift chain centered to move engine forward off the transmission and then re-position it to lift engine out almost vertically---all the while threatening a paint job. With the clip off just lift a couple inches till rear mounts clear and get out of the way, it's coming out. We can EASILY pull a front clip in 30 minutes and when loose have a helper and yourself take hold of it with one hand under the head light ring and the other in the center of the wheel opening as this gives perfect balance. Move just a little forward to clear cowl paint and then raise WAY up for inner fender to clear everything. The fender curves in under the cowl so watch this. For sheet metal and hood alignment we have no problem but some drill an 1/8" hole in each panel and then align with an 1/8" pin when re-installing so everything is in the exact position as before. A dab of dum dum seals these holes. Have a 52 and 57 Chevy pickup (V8's), a 40 Packard (engine overhaul), and a 37 Buick (a/c components) sitting without clips right now so no paint damage is going to happen to any of them.
Evan
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Amen, and Thank You, coilover,
One of my assistants was a friend/neighbor, and the other was a friend/professional mechanic/painter (whom I paid by the hour). They were skeptical of my decision, but the pro had formerly helped with a more tradional upwards lift (with only hood, radiator/housing removed).
We spend much less than 1/2 the installation/re-installation time (engine AND sheet metal), and we spent no $$$ hours dealing with paint chips from assembly/disassembly of front grill parts/etc (1954 trucks).
Two careful people are needed for this technique, and three people are better (my third person was cheap insurance: he was a careful neighbor who took instructions and did not even accept one beer after the job (we put up with the bad jokes he told during the job). | | |
