1 members (klhansen),
70
Mod | | | Forums66 Topics128,094 Posts1,056,064 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2005 Posts: 323 Shop Shark | | Shop Shark Joined: May 2005 Posts: 323 | Hello, wondering if anyone out there can recommend some place that sells a 12 volt conversion kit for a 1953 GMC 302? | | | | | Joined: Jan 2008 Posts: 4,961 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,961 | You really don't need a kit for the engine. All you need is a 12 volt coil that would have come on a 56 model and a ballast resistor. The rest of the vehicle, will just have to change it over. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Kenneth,
What about a Runtz-style resistor for the fuel gauge?
And, of course, light bulbs. | | | | | Joined: May 2005 Posts: 323 Shop Shark | | Shop Shark Joined: May 2005 Posts: 323 | They make kits for the chevy's that include an alternator and brackets. Just looking for something similar for the GMC engines. | | | | | Joined: Jan 2008 Posts: 4,961 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,961 | An alternator bracket that fits a Chev will fit a 302. As for fuel gauge, I was never very concerned about them. I remember guys using a fuel sending unit for a 56 model. I'm not sure how accurate they were. Of course in those days our best indicator was to rock the vehicle and listen to the sloshing. | | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | 6V starter will work fine on 12V. 6V wires are thicker than 12V wires, so you are ahead there.
Ed
| | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | When I converted my 216 to 12 volts, I used a coil that doesn't require an external resistor. So far i have had no problem with it. | | | | | Joined: Jan 2008 Posts: 4,961 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,961 | Low RPM engines such as tractor engines do just fine with internal resistor coils. However, with GMC engines that I ran approaching the 4000 rpm range, a GM type coil with a ballast resistor did better. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | If you can get through to them, ask if the fuel gauge reducer is a separate unit and if it is a Runtz-style reducer. | | |
