4 members (SmalltownTRKGuy, Otto Skorzeny, TrknGMC, TooMany2count), 106 guests, and 8 robots.
Topics128,077
Posts1,056,032
Members48,433
#1234448 09/12/2017 5:44 PM
Hello, wondering if anyone out there can recommend some place that sells a 12 volt conversion kit for a 1953 GMC 302?
You really don't need a kit for the engine. All you need is a 12 volt coil that would have come on a 56 model and a ballast resistor. The rest of the vehicle, will just have to change it over.
Kenneth,
What about a Runtz-style resistor for the fuel gauge?
And, of course, light bulbs.
They make kits for the chevy's that include an alternator and brackets. Just looking for something similar for the GMC engines.
An alternator bracket that fits a Chev will fit a 302. As for fuel gauge, I was never very concerned about them. I remember guys using a fuel sending unit for a 56 model. I'm not sure how accurate they were. Of course in those days our best indicator was to rock the vehicle and listen to the sloshing.
Crusing in the Passing Lane
6V starter will work fine on 12V. 6V wires are thicker than 12V wires, so you are ahead there.
Ed
When I converted my 216 to 12 volts, I used a coil that doesn't require an external resistor. So far i have had no problem with it.
1951 1 Ton Completed
Low RPM engines such as tractor engines do just fine with internal resistor coils. However, with GMC engines that I ran approaching the 4000 rpm range, a GM type coil with a ballast resistor did better.
Found this online but they have the Chevy engines listed and haven't been able to get ahold of anybody to ask about it.
http://www.vintageautogarage.com/19...DQ0yEAQYASABEgKlhPD_BwE&st-t=adwords
If you can get through to them, ask if the fuel gauge reducer is a separate unit and if it is a Runtz-style reducer.
