8 members (68ironhead, jmoore, Joe H, Phak1, 55shaker, 3B, Waveski, 1 invisible),
74
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,154 Posts1,056,834 Members48,456 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2017 Posts: 88 Shop Shark | | Shop Shark Joined: Mar 2017 Posts: 88 | Does anyone know where the axle list on this forum went? I seen it weeks ago and now I cant find it. I any still trying to connect my stock torque tube axle to my non torque tube tranny. The truck is a 54 Chevy 3100 and the engine and tranny came from a 57 3100. I have the rear tranny plate from a 3/4 ton truck that will I think fit the torque tube axle. If I had or could find the correct u joint I would be open to using the torque tube axle but they are impossible to find so it maybe time to look into a different axle. I would like to find an axle the same as stock width, and around a 3.55:1 gearing. I would also like to keep the 6 lug bolt circle and I will be putting some weight in this truck on occasion. For those reasons I don't think an S-10 axle will work. I am open to getting just a different third member and using my stock axle housing, and welding on the correct perches but I have no idea what would fit this axle. I heard at times you need different leaf springs that have a locating pin for the different axle. Will those differernt leafs fit the frame without modification?
Thanks for any suggestions | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Is this what you referred to? Tech Tips - Axels - The Need For Speed"Advance Design (1947.2 — 1955.1) 1-Ton Truck Rear Axle Ring and Pinion Swap!" | | | | | Joined: Mar 2017 Posts: 88 Shop Shark | | Shop Shark Joined: Mar 2017 Posts: 88 | No thats not it but thanks for sharing anyway. It was interesting and helpful to read through. I found the list I was referring to and it wasn't as long as I thought it was. Anyway I read on another forum someone said a Ford 9 inch third member would fit this stock 54 chevy axle housing and give you a yolk for an open drive shaft. I am 99%percent sure thats not true but has anyone ever heard of this? For me keeping the existing axle with brakes and everything and just getting a different third member would be ideal. It seems like very people even talk about this as an option. I heard an early 55 third member would fit the axle. Does anyone know would any other years fit? Would a car differential fit? It seems like car parts are much more common than truck parts. Thanks again | | |
