7 members (Gdads51, TUTS 59, mk72, ShopRag, Stovebolt48, Hush, Otto Skorzeny), 117 guests, and 3 robots.
Topics128,043
Posts1,055,524
Members48,424
#123380 12/04/2006 11:50 PM
ok so im sanding off the old paint and primer and what not on my truck before i prime it. but before i can prime i guess i need to use some sort of degreaser or solvent or something to clean whats left. any recommendations?? i know i always see the painter spray on some sort of solvent and wipe the vehicle down before hitting in with primer on all the tv shows.
#123381 12/05/2006 12:35 AM
'Wax and Grease Remover'.
Can get it at any autobody supply shops.
Someone might also come along and say laquer thinner. A friend of mine was told to use that. Never used it as a 'final wipe' though because we just use wax and grease remover.
-shrug-
#123382 12/05/2006 6:21 PM
Once you get the main grime off (oven cleaner) you can use a concentrated mix of TSP (tri sodium phosphate) which you can buy at any store. I've always used it for this and it works fine.
#123383 12/06/2006 7:51 PM
Junior Member
Junior Member
go to body suppliers and get a gallon of panel wipe, or equivelent, no mess, wipe on wipe off, fast dry, ready for paint.
