| | | Forums66 Topics128,021 Posts1,055,357 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2006 Posts: 172 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2006 Posts: 172 | ok so im sanding off the old paint and primer and what not on my truck before i prime it. but before i can prime i guess i need to use some sort of degreaser or solvent or something to clean whats left. any recommendations?? i know i always see the painter spray on some sort of solvent and wipe the vehicle down before hitting in with primer on all the tv shows. | | | | | Joined: Apr 2001 Posts: 439 Shop Shark | | Shop Shark Joined: Apr 2001 Posts: 439 | 'Wax and Grease Remover'. Can get it at any autobody supply shops.
Someone might also come along and say laquer thinner. A friend of mine was told to use that. Never used it as a 'final wipe' though because we just use wax and grease remover.
-shrug- | | | | | Joined: Apr 2005 Posts: 345 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 345 | Once you get the main grime off (oven cleaner) you can use a concentrated mix of TSP (tri sodium phosphate) which you can buy at any store. I've always used it for this and it works fine. | | | | | Joined: Sep 2006 Posts: 18 Junior Member | | Junior Member Joined: Sep 2006 Posts: 18 | go to body suppliers and get a gallon of panel wipe, or equivelent, no mess, wipe on wipe off, fast dry, ready for paint. | | |
