| | | Forums66 Topics128,087 Posts1,055,999 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2004 Posts: 208 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 208 | I have a 1956 Pickup with an Apache hood. The hood doesn't latch, It doesn't seem to line up right. The guy I bought the pickup from kept it closed with a bungee cord. Is there a way to make it work? | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | no luck, the shape of the 58/9 hood is different than the 5-7 hood, will never fit, the side curves suit the different fender shapes
| | | | | Joined: Jun 2011 Posts: 1,901 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 1,901 | I have a 56 GMC hood not doing anything. I'll keep a slow eye out in the parts wanted section...
| | | | | Joined: Mar 2004 Posts: 208 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 208 | | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | Bart - I didn't look at your pic at first, that isn't an "Apache" hood [58-62], it's a 57 hood, and you should be able to make it work right, the latch mechanism may be frapped or the hinges may need adjusting
| | | | | Joined: Mar 2004 Posts: 208 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 208 | ok, thanks. I'll try adjusting it again. I'll make my son help this time. | | |
