2 members (Gray_Ghost, 1 invisible), 179 guests, and 2 robots.
Topics128,109
Posts1,056,269
Members48,439
#1232747 08/31/2017 1:47 PM
Finding a gasket without the 235 side-stud holes has been a challenge. I ordered this from Rock-Auto:
https://www.rockauto.com/en/moreinfo.php?pk=3658059&cc=1487136&jsn=1
Has anyone purchased one of these? Any reviews? Did it come with the nut rubber-grommets?
Thanks!
1948 Chevy Thriftmaster 3/4-Ton
Poncho "farming" in Ontario
Starting in the DITY
Continuing in the Project Journals
More images
There are only 10 types of people in this world, those who can read binary and those who can't.
I used a steel straight edge and a exacto knife to cut the side straight then filled the holes with gasket silicon, can't tell it's not the original 216 gasket once installed!
1950 Chevrolet model 1434 5-Window Canadian manufactured 1-Ton with Dump Bed / Hoist
You will never stop learning new things, no matter how old you are.
I liked to use a thick low-pressure 216/235 valve cover gasket.
There might be a thick gasket here?
At one time, I had a thick rubber gasket for a 216 (no holes). I have no idea where it came from. It was awesome!
I find that all the 216 valve cover gaskets I buy do not have the correct contour around the valve springs. I have to trim each one in a number of places.
1951 1 Ton Completed
Victor VS 39725
Iv been buying them for years from the "mom and pop" auto parts by me.
the VS39725 is what I ordered from Rock Auto, so that's encouraging wink
More images
Will that gasket work on a 235?
1951 3100
What year 235?
Low-pressure or high-pressure oil system?
4 screw valve cover or 2 bolt valve cover?
The later, 4 valve cover. Wouldn't appear to have holes in the right spot but wondered if it sits "inside" those bolts.
Not super impressed with the fel-pro gasket I've got. For garage work I've actually been sticking with the thick rubber gasket that was on the truck.
1951 3100
I have put the 2-bolt valve cover on a 261 (using the 2-bolt conversion "kit" and older-style valve cover). I dimly recall that the 4-screw holes were covered.
Someone with one near them will most likely post a definitive reply.
