1 members (Hotrod Lincoln),
57
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,094 Posts1,056,066 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2017 Posts: 55 'Bolter | | 'Bolter Joined: Aug 2017 Posts: 55 | Was tinkering with my lights adding small running lights to the low beam side. Question is there a fuse at the light switch on a 1942 1.5 ton flatbed. High beams are working fine . | | | | | Joined: Sep 2010 Posts: 1,706 back yard wrench turner | | back yard wrench turner Joined: Sep 2010 Posts: 1,706 | Check your dimmer switch. Wayne1938 1-Ton Farm TruckStovebolt Gallery Forums1989 Silverado 1996 Mustang GT convertible When I die, I hope she doesn't sell everything for what I told her I paid for it! | | | | | Joined: Apr 2005 Posts: 7,440 Bolter | | Bolter Joined: Apr 2005 Posts: 7,440 | Dimmer switches reside in a hostile environment. Take the connector loose and wire brush the contacts.ðŸ›
| | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy GreggE, as others have said the dimmer switch is the likely culprit, if you still have functioning high beams the light switch should be fine. The dimmer switch switches the power to the different filaments in the headlights, the only other thing I can think of is both your low beams could be burnt out, it does happen, hope that helps. | | | | | Joined: Aug 2017 Posts: 55 'Bolter | | 'Bolter Joined: Aug 2017 Posts: 55 | Thanks for all the help. I found the time to look into it this weekend, so I went to turn my lights on.... the high beams is where I had left them and when I switched to the low beams for some reason they came on (not complaining) Leaving well enough alone for now but I do have plans to remove the switch and clean the contacts as recommended. I believe thats the problem Thanks again for the help.
Gregg | | |
