0 members (), 153 guests, and 1 robot.
Topics128,110
Posts1,056,241
Members48,437
#1233129 09/03/2017 10:45 AM
Was tinkering with my lights adding small running lights to the low beam side. Question is there a fuse at the light switch on a 1942 1.5 ton flatbed. High beams are working fine .
back yard wrench turner
Check your dimmer switch.
Wayne
1938 1-Ton Farm Truck
Stovebolt Gallery Forums
1989 Silverado
1996 Mustang GT convertible
Dimmer switches reside in a hostile environment. Take the connector loose and wire brush the contacts.🛠
3B Offline
Hy GreggE, as others have said the dimmer switch is the likely culprit, if you still have functioning high beams the light switch should be fine. The dimmer switch switches the power to the different filaments in the headlights, the only other thing I can think of is both your low beams could be burnt out, it does happen, hope that helps.
Thanks for all the help. I found the time to look into it this weekend, so I went to turn my lights on.... the high beams is where I had left them and when I switched to the low beams for some reason they came on (not complaining) Leaving well enough alone for now but I do have plans to remove the switch and clean the contacts as recommended. I believe thats the problem Thanks again for the help.
Gregg
