1 members (klhansen),
160
Mod | | | Forums66 Topics128,132 Posts1,056,729 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2012 Posts: 75 Shop Shark | | Shop Shark Joined: Mar 2012 Posts: 75 | oil pump seems pretty basic, wondering where my problem could be? thanks | | | | | Joined: Mar 2010 Posts: 10,298 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,298 | Did it stop registering oil pressure recently? No oil pressure showing on the gauge at all RPM? Is the engine making bad sounds? Do you have the valve cover off to see if oil is getting to the rocker arms? Oil pumps don't go bad very often. Pick up screens do get plugged with sludge however, and gauges can go bad (not often though). Need a lot more information to help you pinpoint your problem.
| | | | | Joined: Feb 2004 Posts: 29,840 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,840 | First, remove the oil pressure line and plumb in a piece of tubing to a catch container. Start the engine and let it idle for a short time to see if any oil gets pumped out. It's possible your gauge has quit, or the line from the engine to the gauge is clogged, The relief valve in the base of the pump could also be stuck open. Have you pulled the distributor to make sure the oil pump drive tab on the bottom of the shaft hasn't broken off? Once the distributor is out, use a piece of 1/2" round stock in a drill motor with a drive tab ground onto the end of it to drive the pump clockwise. Like the logo on Sun test equipment machines used to say- - - - -"We test, not guess!" Jerry
| | | | | Joined: Mar 2012 Posts: 75 Shop Shark | | Shop Shark Joined: Mar 2012 Posts: 75 | thanks guys the motor is newly rebuilt I checked the gauge line with some air pressure and it works screen is clean and so are tubes shaft on distributer is ok but I wonder if I didn't have it seated all the way down ? | | | | | Joined: Feb 2004 Posts: 29,840 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,840 | That's a pretty common mistake. Did you pack the oil pump gears with Vaseline when you assembled the engine? Jerry
| | | | | Joined: Mar 2010 Posts: 10,298 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,298 | You didn't put an o-ring on the distributor base did you? That will allow the distributor to work but not the oil pump.
| | | | | Joined: Mar 2012 Posts: 75 Shop Shark | | Shop Shark Joined: Mar 2012 Posts: 75 | no vaseline just dipped in new oil, no O ring I made the shaft and put it in a cordless drill and spun the oil pump and it registered on the oil pressure gauge I didn't have the pan on just a small tub oil under pump so it basically just poured out the tube for connecting rod jets but it still came up on the oil gauge a bit | | |
