| | | Forums66 Topics128,186 Posts1,057,211 Members48,465 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2014 Posts: 1,293 Moderator for Tons o' Fun , Co-Moderator Driveline Forum | | Moderator for Tons o' Fun , Co-Moderator Driveline Forum Joined: Jul 2014 Posts: 1,293 | I need some advice on how to fix a leak (drip,drip) from the bottom of the steering sector. The leak is coming from between the Steering Gear Worm Bearing adjuster nut and the housing. The exploded view doesn't show any type of seal and I think if there was it would be damaged when you adjusted the nut anyway. Is this a place to use that "form a gasket stuff? Ok, you experienced Bolters' whats the fix ?
Ron - - Dusty53 1954 Chevy 3604In the Gallery Forum "You can't dance with the Devil and then wonder why you're still in Hell." "They will forget what you've said, and they will forget what you have done but they will never forget the way you made them feel." | | | | | Joined: Aug 2013 Posts: 293 'Bolter | | 'Bolter Joined: Aug 2013 Posts: 293 | No gasket on my truck and no leak! What I did is a mix of 2 tubes of 00 Chevron grease and 1/2 cup of Amsoil 90 weight gear oil, mixed together and then put the mixture in a sandwich bag that I cut the corner off of and piped into the box. Of course you could just find the cornhead grease that's recommended in these and Bob's your uncle! | | | | | Joined: Jul 2014 Posts: 1,293 Moderator for Tons o' Fun , Co-Moderator Driveline Forum | | Moderator for Tons o' Fun , Co-Moderator Driveline Forum Joined: Jul 2014 Posts: 1,293 | doyle1950 - I put the cornhead grease in after having replaced the sector shaft bushings and also replaced the housing side cover gasket. This is a very slow but annoying drip.
Ron - - Dusty53 1954 Chevy 3604In the Gallery Forum "You can't dance with the Devil and then wonder why you're still in Hell." "They will forget what you've said, and they will forget what you have done but they will never forget the way you made them feel." | | | | | Joined: Sep 2012 Posts: 306 'Bolter | | 'Bolter Joined: Sep 2012 Posts: 306 | ** I had exactly the same issue with my steering box using John Deere Corn-head grease. I ordered a 2 inch outside diameter red silicone O-Ring and lubed it really well with Vaseline jelly & installed it before putting the large nut on. Snugged it down good and snug. Have not had and evidence of a leak since. | | | | | Joined: Oct 2016 Posts: 916 'Bolter | | 'Bolter Joined: Oct 2016 Posts: 916 | I used Stern's "00" self leveling grease in my box. Of course, that isn't gong to stop the seep that you have...
~ Dave 1950 Chevrolet 3600 3/4-ton with 261 engine & T5 Transmission | | | | | Joined: Mar 2010 Posts: 10,308 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,308 | Anywhere there are threads for adjustments, including the lock nut, calls for Permatex # 2 upon assembling these parts. It remains flexible forever and will seal these areas very well. If you use Cornhead or similar grease and you still have a substantial leak, you need to replace some seals or gaskets.
| | | | | Joined: Apr 2006 Posts: 506 Shop Shark | | Shop Shark Joined: Apr 2006 Posts: 506 | The Shop Manual is very clear. To prevent a leak, (drip, drip) read the paragraph.... Assembly of steering gear
-Tom
1950 Chevy 3100 w/ 1956 235
| | | | | Joined: Jul 2014 Posts: 1,293 Moderator for Tons o' Fun , Co-Moderator Driveline Forum | | Moderator for Tons o' Fun , Co-Moderator Driveline Forum Joined: Jul 2014 Posts: 1,293 | 52Carl and Oilrag- I read that section and did use the permatex everywhere called for except the adjusting nut for the worm bearing, go figure. Thanks guys, I've got the steering sector back out so it will be easy to correct.
