7 members (Samantha, cmayna, 55shaker, Bill Hanlon, TooMany2count, 1955 1 Series, Otto Skorzeny), 102 guests, and 3 robots.
Topics128,071
Posts1,055,901
Members48,429
#1233328 09/04/2017 2:45 PM
2 Offline
I've read a lot of the posts about oil pan installation and have checked and aimed nozzles, cleaned pan. Sealing surfaces are good. I was already to go when a question came to mind. Is a seal or "o" ring required where the oil pipe slips into the oil line in the pan? It seems a tight fit but a seal would improve flow to Babbitt bearings. Nothing in the gasket set looks close. Thanks
216wny #1233360 09/04/2017 5:23 PM
2 Offline
Probably obvious from my question. But I really haven't posted before, truck is a 49 Chevy Panel with a 216. Sorry, rookie mistake.
216wny #1233391 09/04/2017 9:47 PM
Do not know what year you are asking about, but there is not a gasket on the 46.
This Exploded view may help you.
Harold
Harold
216wny #1233393 09/04/2017 9:52 PM
I don't think I've ever seen any kind of gasket or seal on the oil pan/block junction. Somebody probably needs to do some experimenting with an O ring around the male part of the joint to see if it makes a difference, but other than watching oil pressure, how would you measure it?
