9 members (wilbur53, Otto Skorzeny, Greg_H, 68ironhead, WICruiser, Gdads51, Shade Baby, rinemb, 1 invisible),
243
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,095 Posts1,056,075 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2010 Posts: 202 'Bolter | | 'Bolter Joined: Oct 2010 Posts: 202 | The push rods in the L6 235 are supposed to straight? Yes? I checked these by rolling them on a the windshield half that will be installed in the truck and 3 of them had a definite wobble.
I have ordered 3 replacement pushrods from a popular well known truck parts company. The first three were shipped in a padded envelope, and all 3 arrived bent, as were the 3 to replace those which arrived in a shipping tube.
These are supposed to be straight -- no wobble -- aren't they. | | | | | Joined: Feb 2004 Posts: 29,792 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,792 | Yes they're supposed to be straight. If you have access to a lathe and a dial indicator it's a pretty simple operation to straighten them, but new items shouldn't require that kind of attention. Bent pushrods won't spin when the engine is running, but a slight amount of bend probably won't affect how the engine runs. However, they will have a tendency to bend further as they run for a while. Jerry
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | There is no problem posting the name of the supplier.
That information might help others in choosing a supplier, or, cause someone else to also try to get that supplier to be more careful - use a box and bubble-wrap.
Forewarned is forearmed. | | | | | Joined: Oct 2010 Posts: 202 'Bolter | | 'Bolter Joined: Oct 2010 Posts: 202 | There is no problem posting the name of the supplier.
Forewarned is forearmed. The supplier is Jim Carter Truck Parts. I am going to call them tomorrow afternoon and explain the problem. Its looking like they got hold of a batch of mostly bent pushrods. This is a freshly rebuilt engine that has yet to be fired up and perform its camshaft break in. I need to have the lifters and pushrods spinning correctly.
