1 members (klhansen), 90 guests, and 0 robots.
Topics128,050
Posts1,055,641
ok so a few people have told me about the tractor supply co. BPS Implement Paint (need something black, cheap thats going to hold up to the elements for a year or so). So i need to know if i should use the BPS primer as well? I already used a rustoleum primer on the front bed panel and rear cross sill, so do i need to sand that all off and prime with the BPS stuff? btw here is the link to what im talking about and please let me know if this is the wrong stuff:
Paint - http://www.mytscstore.com/detail.as...sonID=456&page=1&productID=18290
Primer - http://www.mytscstore.com/detail.as...sonID=456&page=1&productID=18270
Also if anyone knows if the black paint comes out glossy or flat id like to know. and if it does not come out flat, if there is a similar type of paint that will give me a flat black.
thanks.
The local Tractor Supply here has semi-gloss black
tractor paint, I've sprayed it before. I think it was Valspar brand, not BPS.
Steve
'49 3800
'52 3600
'57 3100
if you used the "rusty metal primer" from rustoleum you could be in for some problems with your top coats due to the "fish oil" base... that oil will bleed through and your top coats will peel off in fairly short order... check the rustoleum website and they give more info on the subject...
bill in va
Watch the black colors. I have noticed that they look great inside but sometimes have a strange color in good light. THis might be a rattlecan thing. I noticed it when I used rustoleum professional (better than average high gloss) to paint over some rust on my black 64. I did it to keep it from rusting more till I can get it done right.
64 & 66 GMC long fleetside 4x4
Cartwright, OK
63,
The BPS black is good stuff. It comes out glossy and is a breeze to work with.
The Valspar/BPS primer is not too bad either. Not as easy as the black paint, but be patient and it will turn out nice.
After using BPS/Valspar, I don't plan on using much rust-o-leum for the visible stuff.
Black is a funny pigment. It often contains a lot of red.
Recently our local election precinct changed the vote-by-mail ballot instructions to use blue pen or pencil rather than black pen, because the black ink had so much red in it that it messed with the ballot counting machines.
Paint & Body Shop moderator
there low gloss black has a nice sheen not a total flat and i think a touch more sheen than john deere blitz black which i plan to run on mine.if you have a john deere dealer close try a puff can to see the color. i liked it........dave
1949 Chevrolet 3100
"When this thing hits 88 miles an hour, you're going to see some serious sh%t." -Doc Brown
