3 members (homer52, Bill Hanlon, 1 invisible),
140
Mod | | | Forums66 Topics128,026 Posts1,055,408 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2006 Posts: 172 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2006 Posts: 172 | ok so a few people have told me about the tractor supply co. BPS Implement Paint (need something black, cheap thats going to hold up to the elements for a year or so). So i need to know if i should use the BPS primer as well? I already used a rustoleum primer on the front bed panel and rear cross sill, so do i need to sand that all off and prime with the BPS stuff? btw here is the link to what im talking about and please let me know if this is the wrong stuff: Paint - http://www.mytscstore.com/detail.as...sonID=456&page=1&productID=18290 Primer - http://www.mytscstore.com/detail.as...sonID=456&page=1&productID=18270 Also if anyone knows if the black paint comes out glossy or flat id like to know. and if it does not come out flat, if there is a similar type of paint that will give me a flat black. thanks. | | | | | Joined: Mar 2004 Posts: 874 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 874 | The local Tractor Supply here has semi-gloss black tractor paint, I've sprayed it before. I think it was Valspar brand, not BPS. | | | | | Joined: Dec 2004 Posts: 56 Member | | Member Joined: Dec 2004 Posts: 56 | if you used the "rusty metal primer" from rustoleum you could be in for some problems with your top coats due to the "fish oil" base... that oil will bleed through and your top coats will peel off in fairly short order... check the rustoleum website and they give more info on the subject... bill in va | | | | | Joined: Aug 2006 Posts: 112 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2006 Posts: 112 | Watch the black colors. I have noticed that they look great inside but sometimes have a strange color in good light. THis might be a rattlecan thing. I noticed it when I used rustoleum professional (better than average high gloss) to paint over some rust on my black 64. I did it to keep it from rusting more till I can get it done right.
64 & 66 GMC long fleetside 4x4 Cartwright, OK
| | | | | Joined: Dec 2003 Posts: 975 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 975 | 63,
The BPS black is good stuff. It comes out glossy and is a breeze to work with.
The Valspar/BPS primer is not too bad either. Not as easy as the black paint, but be patient and it will turn out nice.
After using BPS/Valspar, I don't plan on using much rust-o-leum for the visible stuff. | | | | | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | Black is a funny pigment. It often contains a lot of red.
Recently our local election precinct changed the vote-by-mail ballot instructions to use blue pen or pencil rather than black pen, because the black ink had so much red in it that it messed with the ballot counting machines.
Paint & Body Shop moderator A lone amateur built the Ark. A large group of professionals built the Titanic. | | | | | Joined: Mar 2005 Posts: 576 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 576 | there low gloss black has a nice sheen not a total flat and i think a touch more sheen than john deere blitz black which i plan to run on mine.if you have a john deere dealer close try a puff can to see the color. i liked it........dave 1949 Chevrolet 3100 "When this thing hits 88 miles an hour, you're going to see some serious sh%t." -Doc Brown
