3 members (tclederman, DoubleB, Nick in Manitou), 74 guests, and 2 robots.
Topics128,091
Posts1,056,036
Members48,433
#123282 11/29/2006 2:43 AM
I got the new edition of the Eastwood catalog today and noticed that on pg. 25, they show "Copper Spoons" item #19108. I've seen these before and understand how they work, but I have a few questions for the welders out there!
Can any piece of copper do? Or does it have to be this type of flat panel. I work with copper at the water plant and can get a peice anytime I want and flatten it. Mount it on a stick and weld away. Is it a certain thickness or special type of copper/tin/zink etc. mixture?
Jake
1960 GMC 305A V-6 Gallery Page
Remember, the government cannot give --anything to anyone --that they have not first taken away from someone else.
BUY AMERICAN http://www.stillmadeinusa.com/index.html
#123283 11/29/2006 3:07 AM
V-6,
My two cent guess...
Copper won't stick to the metal if 'welded' and has the ability, if thin, to draw away lots of the heat, which could result in melt-through, plus it is inert and won't contaminate the weld.
I'll bet any old piece of copper would do the trick.
Stuart
#123284 11/29/2006 3:22 AM
I use a scrap of copper pipe that I hammered flat on one end, works well. Brian
My \'64\'s in the Gallery
Pictures in my Photobucket
1964 C10 Custom Cab 350/700R4
1964 Suburban 350/700R4
1979 Ford F350 4x4 400/c6
#123285 11/29/2006 4:10 AM
yep i use a 3/4" pipe that i hammered flat. got a couple of em different lengths that i shape to meet the condition.
I don't suffer from insanity, I enjoy every minute of it!
#123286 11/29/2006 1:51 PM
Thats what I needed to know, I did not feel like spending $29.95 for a small peice of copper!
Jake
#123287 11/30/2006 6:04 AM
Yep, another copper pipe smashed flat. smile
Brian
1948 Chevy Pickup
Chopped and sectioned
owned since 1974 when I was 15.
#123288 11/30/2006 4:51 PM
The only advantage to the spoon is a long handle for positioning. If you flatten the end of the pipe just leave a long un-flattened section for a handle. The hollow pipe will stay cooler; the copper "spoon" will absord ALOT of heat and do it quickly.
#123289 11/30/2006 5:33 PM
I wrapped my pc. of copper pipe around a magnet with an on/off switch. Then I could stick it to the backside and plug firewall holes easily. It will also absorb the heat and decrease warpage.
Curt B.
You Tube
#123290 12/01/2006 3:21 AM
I flattened the pipe out FLAT and it is about a foot long so it is pretty close to a "spoon" with a handle.
Brian
1948 Chevy Pickup
#123291 02/02/2007 12:07 AM
I do heavy duty electrical work and use 1/4 x 4 copper buss bar. I clamp the workpieces by sandwiching them between a central bottom piece and another piece along each side. I welded the length of my fleetside tailgate in a single pass with zero warpage. I takes three peices of copper, but it works really slick. The bonus is this: a near perfect finish on the underside. I guess any heavy gauge copper will work. grin
They named it Apache cause it has a patchy welded here and a patchy welded there.
#123292 02/02/2007 12:54 PM
I've also used a piece of pipe and smashed it...worked well for me.
#123293 02/06/2007 1:38 AM
Copper buss bar about 1/4" thick, just like 59patchy uses. works really well. I just bolted a wooden handle on it. I've used stainless steel in an emergency but you can stick it if not careful. Aluminum plate 3/8" will work also....Rick
'36 Tall cab Chevy 1.5 ton, '36 Low cab Chevy 1.5 ton, '53 GMC 2 ton, '51 GMC 640 5 ton, '47 Dodge 2 ton, '42 GMC CCKW 353 6X6.
