7 members (stlcardinalsguy, Maybellene, Wally / Montana, Wheelie, Otto Skorzeny, Gdads51, MarkT),
188
Mod | | | Forums66 Topics128,078 Posts1,056,022 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2001 Posts: 1,181 'Bolter | | 'Bolter Joined: Mar 2001 Posts: 1,181 | I got the new edition of the Eastwood catalog today and noticed that on pg. 25, they show "Copper Spoons" item #19108. I've seen these before and understand how they work, but I have a few questions for the welders out there!
Can any piece of copper do? Or does it have to be this type of flat panel. I work with copper at the water plant and can get a peice anytime I want and flatten it. Mount it on a stick and weld away. Is it a certain thickness or special type of copper/tin/zink etc. mixture?
Thanks Jake | | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | V-6,
My two cent guess...
Copper won't stick to the metal if 'welded' and has the ability, if thin, to draw away lots of the heat, which could result in melt-through, plus it is inert and won't contaminate the weld.
I'll bet any old piece of copper would do the trick.
Stuart | | | | | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | I use a scrap of copper pipe that I hammered flat on one end, works well. Brian | | | | | Joined: Mar 2005 Posts: 267 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 267 | yep i use a 3/4" pipe that i hammered flat. got a couple of em different lengths that i shape to meet the condition.
I don't suffer from insanity, I enjoy every minute of it!
| | | | | Joined: Mar 2001 Posts: 1,181 'Bolter | | 'Bolter Joined: Mar 2001 Posts: 1,181 | Thats what I needed to know, I did not feel like spending $29.95 for a small peice of copper!
Jake | | | | | Joined: Oct 2000 Posts: 804 Shop Shark | | Shop Shark Joined: Oct 2000 Posts: 804 | Yep, another copper pipe smashed flat. Brian
1948 Chevy Pickup Chopped and sectioned owned since 1974 when I was 15.
| | | | | Joined: Jan 2005 Posts: 62 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2005 Posts: 62 | The only advantage to the spoon is a long handle for positioning. If you flatten the end of the pipe just leave a long un-flattened section for a handle. The hollow pipe will stay cooler; the copper "spoon" will absord ALOT of heat and do it quickly. | | | | | Joined: Mar 2005 Posts: 1,513 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,513 | I wrapped my pc. of copper pipe around a magnet with an on/off switch. Then I could stick it to the backside and plug firewall holes easily. It will also absorb the heat and decrease warpage.
Curt B.
1952 1300 Canadian 1/2 ton restomod You Tube | | | | | Joined: Oct 2000 Posts: 804 Shop Shark | | Shop Shark Joined: Oct 2000 Posts: 804 | I flattened the pipe out FLAT and it is about a foot long so it is pretty close to a "spoon" with a handle.
Brian
| | | | | Joined: Feb 2006 Posts: 50 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2006 Posts: 50 | I do heavy duty electrical work and use 1/4 x 4 copper buss bar. I clamp the workpieces by sandwiching them between a central bottom piece and another piece along each side. I welded the length of my fleetside tailgate in a single pass with zero warpage. I takes three peices of copper, but it works really slick. The bonus is this: a near perfect finish on the underside. I guess any heavy gauge copper will work.
They named it Apache cause it has a patchy welded here and a patchy welded there.
| | | | | Joined: Apr 2006 Posts: 453 Shop Shark | | Shop Shark Joined: Apr 2006 Posts: 453 | I've also used a piece of pipe and smashed it...worked well for me. | | | | | Joined: Jul 2006 Posts: 187 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2006 Posts: 187 | Copper buss bar about 1/4" thick, just like 59patchy uses. works really well. I just bolted a wooden handle on it. I've used stainless steel in an emergency but you can stick it if not careful. Aluminum plate 3/8" will work also....Rick
'36 Tall cab Chevy 1.5 ton, '36 Low cab Chevy 1.5 ton, '53 GMC 2 ton, '51 GMC 640 5 ton, '47 Dodge 2 ton, '42 GMC CCKW 353 6X6.
