6 members (Gdads51, Ponchogl, Otto Skorzeny, Wayne67vert, BillyDon, carbking), 126 guests, and 4 robots.
Topics128,272
Posts1,058,316
Members48,485
#1232323 08/28/2017 1:03 AM
I was so happy with the way my VISE STAND turned out, I decided to build a GRINDER STAND too. LINK HERE
52Carl, do you think this one will fall over and break my leg too? eeeek
Jay
Lugnutz #1232715 08/31/2017 2:22 AM
If you don't have the cat-like agility to get out of the way of slowly falling, heavy items, then you have no business in a shop to begin with. That's my motto anyway. smile
Lugnutz #1232718 08/31/2017 2:31 AM
I usually need a 3' cheater pipe or a big pipe wrench for things I put in my big vice, so if it's not bolted to a big workbench or the floor, wouldn't work the way I use it. Maybe just me. The grinder stand is top notch. I just saw a fellow had added one of those flap disk to the outside of his grind wheel to clean up ends of pipe or whatever your working it. Looks like that would work for you Jay with the side exposed like you have it. I'm going to give it a try also.
Allen
1974 Stingray Corvette
Lugnutz #1232720 08/31/2017 2:39 AM
As I mentioned earlier, I already have a nice bench vise bolted to a heavy table. The vise on the portable stand is for working outside. I frequently work outside and having a vise next to my welder is convenient. I use it to hold metal pieces as I shape them. Nice to hold pieces as I grind too. Sparks and metal dust stay outside to minimize dust inside the shop. The same goes for the grinder.
You guys need to stop busting my chops about the vise stand tipping over. It's not intended for that kind of work because I have another one for that purpose. Or are you just having fun yanking on my chain?
Lugnutz #1232721 08/31/2017 2:46 AM
No worries Jay, I didn't read the whole thread. You didn't get this old being stupid. Seems like you might want to weld some wheels to the back of it though, so they catch as you lean it back since you're going to be moving it a lot. Nice work.
Allen
We have several small stands like that in the shop. I fill the base with concrete and set them on shallow rubber feet, then use a 2 wheel dolly to move them as needed. Works great for smaller work.
Lugnutz #1232738 08/31/2017 11:53 AM
Jay, nice work on the stands. In my shop, floor space is a premium, so a "modular" stand that can accommodate different bits was made. Also allows you to remove the heavy part prior to moving so it doesn't fall on you.. chug (jk)
https://www.garagejournal.com/forum/showpost.php?p=5160575&postcount=1431
Lugnutz #1232739 08/31/2017 12:06 PM
I plan to make a few more stand "table tops" for other tools that I use less often. I have a table top buffer that I'll make a table top so it can mount onto the grinder stand by doing a simple exchange of the top.
Lugnutz #1232760 08/31/2017 3:33 PM
Sorry Lugzy. I am known as a serial chops buster. Thank you for the clarification of the intended use of your pedestal vise. Makes sense.
Carl
MPandC #1232826 09/01/2017 12:30 AM
https://www.garagejournal.com/forum/showpost.php?p=5160575&postcount=1431.
I like that anvil on a pedestal. I need to make one like that. Any tips as to what I should use for the anvil end?
Lugnutz #1232873 09/01/2017 12:12 PM
On the rounded one I used the end of an acetylene bottle cap and just welded the square tube inside. It's not too heavy of steel, but the sheet metal we're using is MUCH thinner and should give first. Here's a sample...
Looks like I needed to tighten the set screw! grin
Moderated by  MNSmith
