2 members (55shaker, moparguy),
72
Mod | | | Forums66 Topics128,128 Posts1,056,684 Members48,452 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#12323 02/22/2003 1:48 AM | Joined: Aug 2001 Posts: 79 'Bolter | | 'Bolter Joined: Aug 2001 Posts: 79 | Hey yall!
I resently purchased a 69 C10, long bed. This truck is totally stock... including those little rims that make the rear end look too narrow. I am looking in to getting some new or used rims that have a better offset than these and am also looking into raising the truck 1-2 inches and putting on some 30 or 31 inch tires. What size 15 inch rim would be a good one? backspacing and all? Also.. would 30s or 31s fit under my truck? If not, what is the largest that I can go? Thanks for all the help.. I will be posting pictures in the gallery later! | | |
#12324 02/23/2003 3:53 PM | Joined: Jan 2002 Posts: 398 Member | | Member Joined: Jan 2002 Posts: 398 | Hey, smokinjoe. Greetings. I believe that 30"/31" tires like you desire will fit under your truck, especially with a slight lift. Does your truck have six-lug hubs? If so, you could use the factory four-wheel-drive wheels (15"x8") from a newer K5 Blazer and they'll fill your wheelwells with those fat tires easy! Nothin' like a truck with fat tires, IMHO Regards, Wannabe
"Don't expect anything and you'll never be disappointed"
#12325 02/24/2003 6:46 PM | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | Smokinjoe, I have a set of slotted ralls on my 69, they were a factory option, I was told. Don't know how hard they are to find, mine came with the truck. 15X8, I think, and six lug. If you haven't found it already, you might try the 69-72 Chevy Board
Fred 52 3600 69 C-10
