1 members (carbking), 77 guests, and 3 robots.
Topics128,196
Posts1,057,393
Members48,471
#1231030 08/20/2017 4:04 AM
Full charge on battery, getting nothing out of starter. Gauges showing draw, cables all checked. Cleaned stomp switch. No help. Any ideas here.
Is this a stock set up with a stomp starter on the floor board?
Crusing in the Passing Lane
Guages will only show draw from ignition, starter load does not go through ampmeter, check starter for ground strap to starter mount bolt, all fresh paint scraped off electric terminals, + and -, stomp making contact with mechanical switch on top of starter(might have to lengthen stomp pushrod) , starter dead-was it checked on the bench?
Ed
Try pushing the switch button on the starter without engaging the pinion gear by pushing the stomp pedal. The starter motor should spin without turning the engine. It's possible you've got bent or damaged linkage that's not moving far enough to push the button as the gear engages the flywheel. Ditto on bench testing the starter before it's installed. You could also try gluing a flat washer onto the switch button with RTV sealer or trim cement as a quick test of the linkage to see if that makes the motor turn as the stomp pedal is pushed.
Pedal of stomp starter mech. can be adjusted via a jam nut where the threaded end connects under the floor. More length of travel pushes linkage a bit further making the connection. Best of luck
1946 1/2-Ton Chevy
I had issues with the starter and even though my ground cable looked good and was tight. It wasn't. If you have one of those 12 volt cables. It's not big enough. I bought a 2/0 gauge and connected it to the bolt on the top of the starter mount. HUGE difference. The cable was about $50 but I'm glad to have it.
Don
Can’t begin to tell you how much I hate the name Stovebolt.
A piece of #0 or larger welding cable makes a great battery cable, especially if you solder the ends onto it.
If your battery cable ever gets warm after use, it is probably too small.
Ed
