| | | Forums66 Topics128,004 Posts1,055,246 Members48,418 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2000 Posts: 1,438 'Bolter | | 'Bolter Joined: Aug 2000 Posts: 1,438 | I was just noticing I have slight play in the driveline u-joint. Can't really see it move but I can feel it. I'm thinking I should not feel any but not real sure. I'm not talking about the play when twisting the driveline where there is some movement with the gears.
Dennis
40 Chevy 1/2 ton
| | | | | Joined: Apr 2005 Posts: 396 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 396 | Any play in a u-joint is not good, it could lead to a helpless feeling on the road. Jerry
| | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | So how do you feel play in a u-joint that is inside a torque tube? | | | | | Joined: Aug 2000 Posts: 1,438 'Bolter | | 'Bolter Joined: Aug 2000 Posts: 1,438 | Ahh, it's easy. Replace it with open drive shaft and Furd rear.
Dennis
40 Chevy 1/2 ton
| | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | New Ujoints are cheap and easy. Do that.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Aug 2000 Posts: 1,438 'Bolter | | 'Bolter Joined: Aug 2000 Posts: 1,438 | Will do. Thanks guys.
Dennis
40 Chevy 1/2 ton
| | | | | Joined: Mar 2010 Posts: 10,270 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,270 | Ahh, it's easy. Replace it with open drive shaft and *********Furd******* rear.
Dennis Well, there's your trouble right there.  Seriously, how many miles on those u-joints? Premature u-joint wear can come from a mismatch between pinion angle and engine angle. Carl
| | | | | Joined: Aug 2000 Posts: 1,438 'Bolter | | 'Bolter Joined: Aug 2000 Posts: 1,438 | Haven't had a working odometer in years but has to be 50k +.
Dennis
40 Chevy 1/2 ton
| | | | | Joined: Mar 2010 Posts: 10,270 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,270 | I would check engine angle with an angle gauge. I would then check the pinion angle. They need to be the same or within +/- 1.5 degrees of each other. There are angled shims available to adjust the pinion angle to match the engine angle. It sounds like you need new u-joints. Don't get cheap and only replace just one (this urge haunts me constantly  ).
