Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
7 members (Oswald, UtahYork, jmoore, baldeagle, 52Carl, tclederman, RLB), 52 guests, and 2 robots.
Topics128,018
Posts1,055,265
Members48,418
#1232255 08/27/2017 4:36 PM
I was just noticing I have slight play in the driveline u-joint. Can't really see it move but I can feel it. I'm thinking I should not feel any but not real sure. I'm not talking about the play when twisting the driveline where there is some movement with the gears.
Dennis
40 Chevy 1/2 ton
DennisM #1232264 08/27/2017 6:00 PM
1 Offline
Any play in a u-joint is not good, it could lead to a helpless feeling on the road.
DennisM #1232309 08/27/2017 11:48 PM
So how do you feel play in a u-joint that is inside a torque tube?
1951 1 Ton Completed
DennisM #1232324 08/28/2017 1:07 AM
Ahh, it's easy. Replace it with open drive shaft and Furd rear.
Dennis
40 Chevy 1/2 ton
DennisM #1232333 08/28/2017 1:43 AM
Sir Searchalot
Sir Searchalot
New Ujoints are cheap and easy. Do that.
DennisM #1232334 08/28/2017 1:44 AM
Will do. Thanks guys.
Dennis
40 Chevy 1/2 ton
DennisM #1232479 08/29/2017 2:05 AM
5 Online: Content
Originally Posted by DennisM
Ahh, it's easy. Replace it with open drive shaft and *********Furd******* rear.
Dennis
Well, there's your trouble right there. smile
Seriously, how many miles on those u-joints? Premature u-joint wear can come from a mismatch between pinion angle and engine angle.
Carl
DennisM #1232481 08/29/2017 2:10 AM
Haven't had a working odometer in years but has to be 50k +.
Dennis
40 Chevy 1/2 ton
DennisM #1232581 08/29/2017 10:12 PM
5 Online: Content
I would check engine angle with an angle gauge. I would then check the pinion angle. They need to be the same or within +/- 1.5 degrees of each other. There are angled shims available to adjust the pinion angle to match the engine angle.
It sounds like you need new u-joints. Don't get cheap and only replace just one (this urge haunts me constantly smile ).
