1 members (Cletus1950),
77
Mod | | | Forums66 Topics128,151 Posts1,057,000 Members48,460 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2017 Posts: 68 Shop Shark | | Shop Shark Joined: Aug 2017 Posts: 68 | How hard is it to replace the king pin and a wheel bearing on a medium duty truck? Always done my own suspension on normal cars and trucks but never on anything heavy duty. | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | The wheel brgs. are not too difficult. The king pins can be. If they are frozen in the axle it can be a tough job getting them out. The new bushings in the spindle have to be line reamed. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Aug 2017 Posts: 68 Shop Shark | | Shop Shark Joined: Aug 2017 Posts: 68 | So basically have it done? Bc that sounds undoable lol | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | If you can remove wheel bearings and replace that's simple enough.
King pins could still be done mostly by you. If they come out then only need to take spindles to the machine shop to ream or hone bushings. If they don't come out you can remove axle with spindles attached so they can first press the pins out, then fit bushings and ream/hone.
Only difference in a medium duty truck and the smaller ones is weight/size of the parts, they go together the same.
| | | | | Joined: Jul 2014 Posts: 32 'Bolter | | 'Bolter Joined: Jul 2014 Posts: 32 | I just completed all mine, the hard part for me was getting the old bushings out of the spindle's. We used a press to get them installed and all is great now.
1954 Chevy COE 1948 Metro Van 1979 RH drive mini cooper
| | | | | Joined: Aug 2017 Posts: 68 Shop Shark | | Shop Shark Joined: Aug 2017 Posts: 68 | I will get with you guys thanks. Been busy but I will get with you guys for questions. | | |
