2 members (JeffA, Mike B), 167 guests, and 2 robots.
Topics128,162
Posts1,056,938
Members48,458
What is the Torque for the 4 bolts oil pump cover ?
The Shop Manual does not give a torque value.
Does the pump cover gasket need any gasket forming material ?
Thanks in advance. Michael...
1954 Chevy 3104 3 Window Hydra-Matic in my family for over 60 Years
Once in a while you get shown the light in the strangest of places if you look at it right... "Scarlet Begonias" Grateful Dead 1974
They're standard Grade 5 1/4-20 bolts- - - - -8 ft/lbs. (96 in/lbs) or so should be plenty. A drop of blue Loctite on the threads would be a good idea. I'd install the gasket dry, although the later V8 pumps don't use a gasket at all.
Thanks again Jerry. Torqued bolts to 8 ft./lbs. with a drop of blue Loctite and tightened pipes finger tight + 1 turn. The gaskets are very thin.
