1 members (CATMAN),
158
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,162 Posts1,056,935 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2009 Posts: 433 'Bolter | | 'Bolter Joined: Sep 2009 Posts: 433 | What is the Torque for the 4 bolts oil pump cover ?
The Shop Manual does not give a torque value.
Does the pump cover gasket need any gasket forming material ?
Thanks in advance. Michael...
1954 Chevy 3104 3 Window Hydra-Matic in my family for over 60 Years
Once in a while you get shown the light in the strangest of places if you look at it right... "Scarlet Begonias" Grateful Dead 1974
| | | | | Joined: Feb 2004 Posts: 29,858 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,858 | They're standard Grade 5 1/4-20 bolts- - - - -8 ft/lbs. (96 in/lbs) or so should be plenty. A drop of blue Loctite on the threads would be a good idea. I'd install the gasket dry, although the later V8 pumps don't use a gasket at all. Jerry
| | | | | Joined: Sep 2009 Posts: 433 'Bolter | | 'Bolter Joined: Sep 2009 Posts: 433 | Thanks again Jerry. Torqued bolts to 8 ft./lbs. with a drop of blue Loctite and tightened pipes finger tight + 1 turn. The gaskets are very thin.
