7 members (cmayna, GusG, FAST55, Phak1, 3B, Gray_Ghost, 1 invisible),
74
Mod | | | Forums66 Topics128,185 Posts1,057,281 Members48,467 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2017 Posts: 88 Shop Shark | | Shop Shark Joined: Mar 2017 Posts: 88 | I recently picked up a 235 engine out of a 57 chevy 3100. I put it in my 54 chevy 3100 and I am going to try and get it running in the next few weeks. I thought I could find a new aftermarket carb but so far my search has turned up nothing. Maybe the stock carb works well enough that aftermarkets are not needed or available. What does everyone run for carbs? So far I have not even found a rebuild kit for my stock carb. Can anyone suggest a source for that? The engine has not ran for 30 years so I'm sure the carb could use a rebuild if I decide to use it.
Thanks | | | | | Joined: Dec 2008 Posts: 1,923 'Bolter | | 'Bolter Joined: Dec 2008 Posts: 1,923 | The "universal" carburetor you may find... isn't. | | | | | Joined: Apr 2005 Posts: 7,441 Bolter | | Bolter Joined: Apr 2005 Posts: 7,441 | Kits are available at most of the usual vendors. You will need the make and numbers off it in order to get the right one. Also, member Carbking sells carb repair parts. You have enough posts to send him a PM. Search the members list and click on his handle for contact info.ðŸ›
| | | | | Joined: Feb 2004 Posts: 29,880 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,880 | The lLast time I checked, Carbking was not accepting PM's. Check his profile and use the website that's posted for his business. If you're dealing with a Rochester, you're probably out of luck with Jon- - - - -he's about as fond of those carburetors as I am of rattlesnakes. Jerry
| | | | | Joined: Mar 2010 Posts: 10,309 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,309 | I believe Carbking has quite the inventory of carbs for sale.
| | | | | Joined: Jan 2017 Posts: 308 'Bolter | | 'Bolter Joined: Jan 2017 Posts: 308 | I just had an 848 head and A Tom Langdon 32/36 installed in my 1954 235. Purrs like a kitten and no leaks..try it you'll love em--Bill | | | | | Joined: Nov 2002 Posts: 2,774 Carburetion specialist | | Carburetion specialist Joined: Nov 2002 Posts: 2,774 | Jerry - you misunderstand. I LOVE Rochester type B carburetors. Best excuse in the world to sell a customer a Carter to replace it! And you are correct about PM's. While I understand the owners of the website are trying to help member communications, every website has a different method of PM. Remember the cliché with the old dog, and tricks  Easier for me to accept emails (they all work the same way) than to try to figure out PM protocol for each website. And Jonald - repair kits for your original carb are quite available. You simply need the number of the triangular tag when ordering. Jon. Good carburetion is fuelish hot airThe most expensive carburetor is the wrong one you attempt to modify. If you truly believe "one size fits all," try walking a mile in your spouse's shoes!The Carburetor Shop | | | | | Joined: Nov 2002 Posts: 2,774 Carburetion specialist | | Carburetion specialist Joined: Nov 2002 Posts: 2,774 | The "universal" carburetor you may find... isn't. Or in other words "one size fits................................NOTHING!" Jon. Good carburetion is fuelish hot airThe most expensive carburetor is the wrong one you attempt to modify. If you truly believe "one size fits all," try walking a mile in your spouse's shoes!The Carburetor Shop | | |
