BUSY BOLTERS Are you one? The Shop Area
| | Click on image for the lowdown.
2 members (wylie, TPR57C),
552
robot. | Key: Admin,
Mod | | Forums66 Topics126,777 Posts1,039,270 Members48,100 | Most Online2,175 Jul 21st, 2025 | | | Joined: Jul 2017 Posts: 6 New Guy | New Guy Joined: Jul 2017 Posts: 6 | After my truck stays parked for a few days the gas in the fuel pump glass bowl is gone. I order a new fuel pump thinking the check valve in the pump is bad. Would you'll agree? Thanks
Great little Chevy truck
| | | | Joined: Feb 2000 Posts: 4,886 'Bolter | 'Bolter Joined: Feb 2000 Posts: 4,886 | Probably not, modern gas evaporates much quicker then it used to. Most everybody on this site has to crank the engines for a short time to refill the carburetors. | | | | Joined: Feb 2001 Posts: 1,094 'Bolter | 'Bolter Joined: Feb 2001 Posts: 1,094 | LeLou, Down here in south La. with the heat we've been having the gas is just evaporating. If I don't start my truck every couple of days I will have to crank it a bit because the carb will be empty.
Tommy 59 apache 1/2t 261 short stepside | | | | Joined: Jul 2017 Posts: 6 New Guy | New Guy Joined: Jul 2017 Posts: 6 | Tommy your right about the heat in south louisiana, but do you think the fuel in the fuel pump will evaporate to?
| | | | Joined: Apr 2005 Posts: 7,442 Bolter | Bolter Joined: Apr 2005 Posts: 7,442 | Lelou , we might be able to give you some suggestions if you would tell us what your working on. It's always best to lead off your posts with a short description of what truck your working with, i.e.; 1955 1st series w/235 and Rochester carb losing fuel when it sets for awhile. Help us help you.ðŸ‘ðŸ»
| | | | Joined: Feb 2013 Posts: 250 'Bolter | 'Bolter Joined: Feb 2013 Posts: 250 | It's a big problem here in Hawaii too. Is there a check valve I could install in the gas line closer to the carb to minimize the cranking time to refill it? | | | | Joined: Feb 2001 Posts: 1,094 'Bolter | 'Bolter Joined: Feb 2001 Posts: 1,094 | LeLou,
Maybe there is a check valve in the pump, I don't know. I don't have a pump with the glass bowl, just my experience that a few days without running the truck and the carb. is dry.
Tommy 59 apache 1/2t 261 short stepside | | | | Joined: Apr 2005 Posts: 2,832 'Bolter | 'Bolter Joined: Apr 2005 Posts: 2,832 | Every machine I have that sits awhile has an electric priming pump on it; fork lift, compressor, and old cars/trucks. Flip electric pump on till it changes sound then hit starter and they fire instantly. Once started electric pump is turned off as the mechanical pump will draw through it just fine.
Evan
| | | | Joined: Mar 2010 Posts: 10,059 Renaissance Man | Renaissance Man Joined: Mar 2010 Posts: 10,059 | How long do you have to crank the starter for the pump to fill the carb and start?
| | | | Joined: Jul 2017 Posts: 6 New Guy | New Guy Joined: Jul 2017 Posts: 6 | 52Carl In my opinion to long. I'm worried about a 6volt starter on a 12volt battery overheating. What i'm trying now is shutting off the valve at the gas tank and monitoring the gas lost in the fuel pump bowl. That would tell me if the check valve in fuel pump is leaking
| | | | Joined: Sep 2001 Posts: 29,262 Bubba - Curmudgeon | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,262 | 2 seconds 5 seconds 10 seconds 20 seconds ? | | | | Joined: Feb 2000 Posts: 4,886 'Bolter | 'Bolter Joined: Feb 2000 Posts: 4,886 | Fuel evaporating out of the carb is normal, they all do it. Once the carb is dry, the float opens the needle and seat. The fuel now evaporates out of the line and filter by way of the seat opening. It continues down the line to the pumps, where the check valve should seal off the main fuel line.
Adding a 1/4 turn shut off at the carburetor inlet will minimize cranking, but then you need to be under the hood overtime you go to start it. Electric primmer pump is the quickest and easiest fix. | | | | Joined: Feb 2013 Posts: 250 'Bolter | 'Bolter Joined: Feb 2013 Posts: 250 | I just Googled 'fuel line check valve' and came up with several different options, some under $10. If a check valve was mounted up by the carb it should eliminate the evaporation of fuel in the line from the pump. Any reason not to install one of these? | | | | Joined: Mar 2010 Posts: 10,059 Renaissance Man | Renaissance Man Joined: Mar 2010 Posts: 10,059 | 52Carl In my opinion to long. I'm worried about a 6volt starter on a 12volt battery overheating. What i'm trying now is shutting off the valve at the gas tank and monitoring the gas lost in the fuel pump bowl. That would tell me if the check valve in fuel pump is leaking Do not worry about the 6 volt starter fed by 12 volts. If the starter isn't cranking the engine over smoothly and rapidly, check/clean all cable connections, or have the starter rebuilt or find another one. They go bad regardless of whether they are fed by 6 or 12 volts. Install your new fuel pump to see if it solves your problem. A good 6 volt starter fed by 12 volts with a good fuel pump, with clean/open/leak-free fuel lines should fill the carburetor bowl in less than 10 seconds. Carl
| | | | Joined: Jul 2017 Posts: 6 New Guy | New Guy Joined: Jul 2017 Posts: 6 | Thanks Carl, I agree, fuel pump coming in. I'll let you know how comes out. Right now i'm cranking over or close to a minute.
| | | | Joined: Aug 2013 Posts: 217 Shop Shark | Shop Shark Joined: Aug 2013 Posts: 217 | Just went out and started up my '55. Its been sitting in Calif heat for 2 weeks due to my back surgery. Cranked over with ignition off until steady pressure on pressure guage. Then turned on ignition, 3 pumps of accelerator pump, and it fired right up. | | |
