3 members (klhansen, Ole49GMC, HandyAndy), 84 guests, and 2 robots.
Topics128,113
Posts1,056,580
Members48,448
Fox
Offline
My old harness is a rat's nest and an extreme fire hazard. I don't want the hassle of repairing or creating my own. I am looking at
a reproduction from some of the vendors. I'm not going for originality, but something that I can plug and play so to speak. Classic parts has one listed that is for 53-54 Chev/gmc with an alternator. I want to go alternator but will this harness have provisions for turn signals? I am still awaiting a reply from CP.
1970 Chevrolet C10
1950 Chevrolet 1-Ton Dually
"Ole Red Girl"
More pictures here
Parts trucks-
The speedway.com harness seem to be the deal of the net.
Fox
Offline
However, I can't seem to find a speedway harness that isn't specifically for a "stocker." I am not going to have efi, power windows, a/c, rocking stereo, extra lighting, door poppers, tilt if ididit column, etc. I am just looking for a stock ish alternator harness (several of which I have found) that incorporates turn signals and power wipers (maybe in the future). Has anybody gone down this road?
1970 Chevrolet C10
"Ole Red Girl"
More pictures here
Parts trucks-
Riding in the Passing Lane
If you get a stock type plug & play it will be the easiest way to go but It is expensive & it is still old fashioned with limited fuses & circuit protection. You will probably have to add your own wiring for the turn signals, radio, & heater, as these were dealer installed items. I use the Speedway harnesses but you need some electrical experience to do it. I lay the harness out on the table & cut off any circuits that won't be used. Leave a short amount of wire & bundle the unused wires so if you add something latter it will be there.
1972 Chevy c10 Cheyenne Super
Fox,
The Classic Parts "standard" "stock" wiring harness is a nice appearance-match for original 1953/54 truck wiring. They include extra wires for turn signals. You can hardly beat the quality and the price.
Is you cab and steering-column/wheel 53 or 54?
U
U Offline
Part # : 52-026 It will have wiring for the park lamps, and it is set up for double contact, so the park lamps can function as turn signals.
(Information Per Classic Parts chat)
Edit- I got this one for a 55.2 & it is a super easy harness to install.
Brad
Wrench Fetcher, PhD
Fox
Offline
The cab and column are 53.
Brad, are you running a gen or alternator? Pros during install, cons? Did the task force have signal lights already or did you have to upgrade your stockers like I am trying to do?
One last question:
I would like to maybe one day be able to toe my camper with this old one ton. Would this harness suffice (52-026) for towing?
1970 Chevrolet C10
"Ole Red Girl"
More pictures here
Parts trucks-
U
U Offline
This harness will probably break if you tow a camper with it..
I'm just joking, but what do you mean? Do you mean 'does it have trailer light connections?'
I thought I linked to a harness for an alternator but I probably messed up... anyways, I have an alternator. The task force did have signal lights when I got it, but Ray Charles did the installation. They were not factory or dealer installed, in other words. I currently am only running a single tail light, but I have function checked the old turn signals & switch with the new wiring harness. It worked fine.
Good instructions are provided with the harness & the wires are clearly labeled with a number. Straightforward stuff .
I did not note anything in my truck journal regarding the wiring harness installation. I ran most of the wiring to relax from other tasks that were frustrating. I can't think of any cons with it.
Brad
Wrench Fetcher, PhD
Fox
Offline
My error Brad, your link was for alternator. I need to pay more attention! Yes, I was wondering about tailed light connection possibilities.
1970 Chevrolet C10
"Ole Red Girl"
More pictures here
Parts trucks-
U
U Offline
I don't know about the trailer hook-up/connectors. I've added the (trailer light) capability to farm/hunting ATVs & vehicles with the 4 or 7 prong wiring kits... I would have to ask for help on the 55.2 if I decided to have a trailer light hook-up. The classic wiring harness has a lot (several, maybe 6?) of extra wiring apparatuses included. I'm not sure off-hand what the instructions said they were for.
Original wiring/lamps on my truck. My Great uncle towed his jon boat with the truck; it looked like he wired a cigarette lighter 12v outlet to connect the trailer lamps. I'm a bit young to know this practice, so maybe someone else has done this- it could be an option?
Brad
(edit - looking at those pictures reminded me: the 12v connection on the shade-tree torch welded "towing package" was functional in 2011 when I got the truck. I would have to find pictures to see where the wiring was routed. It would be easier if somebody explained how to make a trailer light hook-up.)
Wrench Fetcher, PhD
