0 members (),
200
0
Mod | | | Forums66 Topics128,048 Posts1,055,540 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2000 Posts: 506 Shop Shark | | Shop Shark Joined: Dec 2000 Posts: 506 | Has anyone experienced any disadvantages with thick gears vs spacers.
"Drugs are money, money is power, power is security." - Kent Heiner Nedrow population 2212 Carbon footprint family of 2/11 tonnes of CO2/yr
| | | | | Joined: Feb 2000 Posts: 5,197 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,197 | The only difference is the weight, the spacing is the same once installed. I have set up a couple with no problems. I have also used spacers with no problems, but would choose the one piece gear over spacer and gear. | | | | | Joined: Feb 2004 Posts: 29,756 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,756 | A spacer is a shade tree work-around to substitute for having the right ring gear carrier assembly. The most common problem with using a spacer is a rhythmic hum caused by variations in the runout of the ring gear. It's OK to run a spacer on a race car where the noise is masked by open exhaust headers, but I'd be reluctant to do it on a street-driven vehicle. Even us deaf old geezers can hear a low-pitched hum! Jerry
| | | | | Joined: Dec 2000 Posts: 506 Shop Shark | | Shop Shark Joined: Dec 2000 Posts: 506 | Thanks everyone that's what I had hoped the answer would be.
| | | | | Joined: Dec 2000 Posts: 506 Shop Shark | | Shop Shark Joined: Dec 2000 Posts: 506 | Update, the rear gear change in the Buick rear from 2:73 to 3:73 (thick gears) from Richmond Gear co went ok.
