6 members (Otto Skorzeny, UtahYork, delky, val, 2 invisible), 55 guests, and 3 robots.
Topics128,030
Posts1,055,424
Members48,422
#1230504 08/17/2017 11:00 AM
Has anyone experienced any disadvantages with thick gears vs spacers.
"Drugs are money, money is power, power is security." - Kent Heiner
Nedrow population 2212
Carbon footprint family of 2/11 tonnes of CO2/yr
52pu #1230543 08/17/2017 2:13 PM
The only difference is the weight, the spacing is the same once installed. I have set up a couple with no problems. I have also used spacers with no problems, but would choose the one piece gear over spacer and gear.
52pu #1230552 08/17/2017 2:32 PM
A spacer is a shade tree work-around to substitute for having the right ring gear carrier assembly. The most common problem with using a spacer is a rhythmic hum caused by variations in the runout of the ring gear. It's OK to run a spacer on a race car where the noise is masked by open exhaust headers, but I'd be reluctant to do it on a street-driven vehicle. Even us deaf old geezers can hear a low-pitched hum!
52pu #1230582 08/17/2017 5:11 PM
Thanks everyone that's what I had hoped the answer would be.
52pu #1235665 09/20/2017 5:18 PM
Update, the rear gear change in the Buick rear from 2:73 to 3:73 (thick gears) from Richmond Gear co went ok.
