| | | Forums66 Topics128,049 Posts1,055,693 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2005 Posts: 123 Shop Shark | | Shop Shark Joined: Nov 2005 Posts: 123 | I removed a 216 engine with 4 speed out of my 1950 3600. I have a donor motor which is a 235 from a 1956 Belair which was an automatic. I want to put the 4 speed behind the 235. My questions are: which pilot bushing should I get? what about pressure plate? match the one from the 216 which is 10 3/4" anything else I should look at? Thanks Ed
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | If you are staying 6v, use the flywheel, clutch-assembly, and starter from that truck.
Maybe someone knows a part-number/supplier for the correct pilot bushing for the Powerglide engine? I'll search for one, and post back here if I find one. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | 1959 Chevrolet Bel Air L6 235 3.8L (3852cc) Only Used For Automatic Transmission Conversion; Powerglide to Manual Transmission; 1.060 In. O.D. Dorman 690-034 http://www.dormanproducts.com/itemdetail.aspx?ProductID=18310&SEName=690-034Wait to hear from others to confirm this is what you need. | | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | One could even check the dimensions of the trans and engine.
Ed
