2 members (NJC, baldeagle),
33
Mod | | | Forums66 Topics128,014 Posts1,055,327 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2004 Posts: 56 'Bolter | | 'Bolter Joined: Dec 2004 Posts: 56 | I'm re-installing the two-piece windshield in my '53. I've got the deluxe weatherstrip, and I want to install the s.s. trim. I searched through some of the old posts for tips. But I just saw an article in the Jan. '07 "Rod and Custom" magazine about installing 50's era windshields. The guy used a lubricant "similar to petroleum jelly" when he bedded the s.s. trim in the channel. Does this really help, and anyone know what kind of lubricant to use? I don't want to use something that's not compatible with the rubber. Should I just use petroleum jelly? Or use something else, like silicone lubricant?
Many thanks. | | | | | Joined: Nov 2001 Posts: 1,517 'Bolter | | 'Bolter Joined: Nov 2001 Posts: 1,517 | the s.s. trim has to go in the rubber while the windshield is out. it all goes in as one unit......rubber,glass,s.s.trim. | | | | | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | I use an, ahem, "personal lubricant", the slippery non-viscous natural-feeling kind. It is water based and very slick, and eventually evaporates away and is rubber-compatible. It also helps to get the rubber warmed up to about 80 degrees.
Paint & Body Shop moderator A lone amateur built the Ark. A large group of professionals built the Titanic. | | | | | Joined: Apr 2005 Posts: 345 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 345 | Josiah, You're talking about the weatherstrip rubber right? | | | | | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | Yeah, as far as you know
Paint & Body Shop moderator A lone amateur built the Ark. A large group of professionals built the Titanic. | | | | | Joined: Jul 2004 Posts: 427 Shop Shark | | Shop Shark Joined: Jul 2004 Posts: 427 | Soapy water or window cleaner will do the trick.
Lay the gasket on a flat surface, install the glass then the stainless minus the center piece. flip the whole assembly over and install an 1/8 in. rope in the groove that the pinchweld will go in, overlaping at the ends of the rope when u get all the way around. Spray around the rope and gasket w/ same lube,Get help putting the assembly in the opening of the truck and start pulling on the rope, pulling towards the center of the glass. As the gasket starts coming over the pinchweld have the help pat the glass near where your pulling w/ a flat hand on the out side to help seat it. Do this until your all the way around. Lastly install the center strip.
Hope this helps
Wilbur | | | | | Joined: Apr 2005 Posts: 2,832 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,832 | Here's an addition to Josiah's "personal" lubricant. What works really good, washes away with water, is around nearly every shop, and doesn't hurt paint is plain old GoJo. It's slippery as snot and has the plus factor of leaving you with clean hands. Also works great for sliding sparkplug wires through boots.
Evan
| | | | | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | Don't use the gritty gojo, though, it will scuff the paint and interfere with the seal.
Paint & Body Shop moderator A lone amateur built the Ark. A large group of professionals built the Titanic. | | | | | Joined: Feb 2006 Posts: 117 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2006 Posts: 117 | just a word of caution... If you decide to use a lubricant to help slide things together, use something that will dissipate quickly. Silicone sprays tend to hang around for a long time and can make the glass pop out very easily once installed. Also, having a buddy for extra hands is a good idea!  Good luck with the install... Dano
my truck gets better every day...every PAYDAY | | | | | Joined: Aug 2004 Posts: 143 Shop Shark | | Shop Shark Joined: Aug 2004 Posts: 143 | I was a manager in an automotive assembly plant in the 1990s. We used Dawn dishwashing liquid to install stuff like weather stripping, gromlets, rubber parts and windshield gaskets. Slick, clean and washes right off. I've used it many times on projects. Cheap and reliable.
It never costs more to ask and it never costs more to think big.
| | | | | Joined: Jan 2006 Posts: 586 Shop Shark | | Shop Shark Joined: Jan 2006 Posts: 586 | I would stick to the dishsoap for automotive use and the "Personal lube" for it's intended use !!!
Wanted Good Woman: Must be able to cook , clean , sew , tune engines and polish trucks. Must have old Stovebolt and garage. Please send picture of old Stovebolt and garage.
| | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | So now, to finish this, does anyone apply sealant and if so what kind? As you can see I have not reached this point yet. | | | | | Joined: Dec 2004 Posts: 56 'Bolter | | 'Bolter Joined: Dec 2004 Posts: 56 | Thanks to all. Especially that 'personal lubricant' trick from "4onthefloor." Great tips and great discussion. But like "truckernix", I'm curious about sealant. Mine is garage-kept, but to-seal-or-not-to-seal? The article I read recommended 3M Bedding & Glazing Compound #8509. Appreciate the help. | | | | | Joined: Jan 2006 Posts: 586 Shop Shark | | Shop Shark Joined: Jan 2006 Posts: 586 | NO sealant, except to seal a bad leaker.It is a mess if you have to remove the glass at some point.
| | | | | Joined: Jul 2004 Posts: 427 Shop Shark | | Shop Shark Joined: Jul 2004 Posts: 427 | 3m bedding & glazing compound is the recommended sealer, that's what I use on most gasket installs. The only problem is the ooze out that continues well after the install and needs to be cleaned up and can easily be done with window cleaner and a single edge razor blade. | | |
