4 members (SmalltownTRKGuy, Otto Skorzeny, TrknGMC, TooMany2count), 106 guests, and 8 robots.
Topics128,077
Posts1,056,032
Members48,433
#1229467 08/10/2017 5:41 PM
Moderated
Moderated
My GMC 270 has what appears to be a 7/8" pulley on the crank and on the water pump. The ac delco generator has another sized pulley. As a result I am shredding belts. I am struggling to find a pulley for the generator. Any advice, contacts, links etc. would be appreciated.
1 Offline
7/8 inch? That seems a bit large. Chevy's of those years have a 5/8 inch pulley at crank, water pump and generator.
7/8" on my 54/55 GMC 270
I think I found one, somehow, on Rockauto.com. Someone on oldGMCtrucks.com gave me a brand and part number, I think.
That person alo suggested using a 3/4" belt as a fall-back.
I'll see if I can find that info.
Here is the info: MPB the belt p/n is 2190637 = Napa p/n NBH2528437 $29.99, specs outside circumferenece 44.3", top width .875"
With 55 amp generator p/n 2135530 = Napa p/n NBH2530467 $33.99, specs outside circumference 47.28", top width.9375.
Gates TR28437 (7/8 X 44 1/4)(22mm X 1125mm) - NAPA had it
Here it tis - check for it locally - Rockauto's shipping/taxes might be beatable
Here are other sources.
Crusing in the Passing Lane
'54 GMC has 7/8 belts. Search at alternator/gen. shop for the correct pulley.
Ed
Ed
belts - multiple belts?
Does the correct pulley have two grooves?
Tom, I tried to send you a pm, but apparently you are over your topic limit.
I have a complete generator with a 7/8 pulley off a '54 302. Hasn't been tested, but looks and feels runnable. Certainly rebuildable.
6 volt I'm assuming. $50+$14 shipping. Let me know.
Roger Z.
This is not the Swap Meet.
That poster has only been here once - the time he made that one post.
For good reason, he connot use the Sawp Meet until he has made a few more posts.
He could have put his email address in his profile.
If one does not need them, not have to use all belts.
Ed
