| | | Forums66 Topics128,159 Posts1,057,033 Members48,460 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2015 Posts: 48 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2015 Posts: 48 | I hate to be the one to start a thread on anything oil related but here goes. I have a 1949 GMC 1 ton with original 4spd and 302 and did the rear end swap. An old local mechanic stopped by and told me he always mixed 90W gear oil with equal amount STP to quiet the gear whine. He also added "some" STP to the tranny. I'm hoping to do some long distance trips with my truck and would like to reduce noise for driving pleasure. Any consensus on alternate lubricants that aren't snake oil? I've already used rattletrap on the interior of the cab and topped that with glued on reflectix to help with noise and heat. I'm very happy overall with all the mods but since I will be draining the gear box and diff again soon I thought I'd ask. | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | What is the rear end swap?
Did you put in any new bearings in rear end and axles? | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | I don't think I would put more then just a little STP in the rear end. Rear end lube is specially designed for Hypoid gears which require extreme pressure lubes. Use a GL -5 gear lube. I don't think it will cut down on noise anyhow. I have tried different lubs to fight gear whine & none have been sucsesful. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Feb 2004 Posts: 29,871 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,871 | Lube manufacturers do a great deal of research and put additives in their products based on facts, not guesswork or "old mechanics' tales". Messing with the hypoid lubricants in rear end grease would be unwise at best, and possibly a disastrous mistake. We used to use straight mineral oil without hypoid additives in Fuller Roadranger transmissions in the big rigs to avoid getting carbon deposits and early failure of synchronizer rings on the air-shifted range selector synchros. I don't think that would be a concern on a stovebolt transmission. Just use the same hypoid lube in the transmission and the rear end.
I've even seen some shade tree wrench jockeys add a couple of handfuls of sawdust to a rear end to try to quiet down gear noises- - - - -that didn't work, either! Jerry
| | | | | Joined: Jan 2015 Posts: 48 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2015 Posts: 48 | I replaced wheel bearings all the way around but the rear end swap was a pumpkin swap from a 1972 3/4 ton pick-up with automatic transmission. It gave me a 20% speed increase. This is covered pretty well in the one ton forum. That project was only 1/2 days work and the results were immediate and pretty dramatic. I now can cruise at 50-55 and pass at 60 if I need to (can't wait for someone slow enough that I can pass)! Overall this makes my truck pretty balanced between the power (302 with Stromberg 2 bbl), braking (one ton disc conversion in front) and handling ( rebuilt knee action shocks), and safety (55 mph). I can live with the gear whine but hoped there might be something else that makes it more enjoyable to use.
| | | | | Joined: Feb 2000 Posts: 5,233 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,233 | What does the 1972 manual recommend for gear oil? With this lower ratio, the noise should be less, due to lower rpms, so use what is recommend for '72 trucks and you should be fine. | | | | | Joined: Sep 2013 Posts: 1,367 'Bolter | | 'Bolter Joined: Sep 2013 Posts: 1,367 | This is what I plan to try in my HO52, 4.11 geared rearend. Would already have given it a shot but have had the agony of helping my baby brother deal with his 21 year daughters death in an auto accident. Other driver crossed the center line, hit her head-on. No Chance.
RonR
1951 3600 with Clark flatbed, T5, 4.10 rear 1970 340 Duster 1990 5.0 V8 Miata (1990 Mustang Gt Drivetrain) 1964 CJ5
